Load mmpk file
1281
11-02-2017 07:45 AM
LionelGOUBET
I use android 100.1.0 and I try to load a mmpk file in android.
I see my map but it is empty no layers visibled !!
What's the problem ?
I don't understand ...
// create the mobile map package
        mapPackage = new MobileMapPackage(mmpkFile);
        // add done listener which will invoke when mobile map package has loaded
        mapPackage.addDoneLoadingListener(new Runnable() {
            @Override
            public void run() {
                // check load status and that the mobile map package has maps
                if(mapPackage.getLoadStatus() == LoadStatus.LOADED && mapPackage.getMaps().size() > 0){
                    Log.e(TAG, "***************** SUCCESS CHARGEMENT MMPK ********************");
                    // add the map from the mobile map package to the MapView
                    ArcGISMap map = mapPackage.getMaps().get(0);
                    if (map != null){
                        _mapView.setMap(map);
                        map.addDoneLoadingListener(
                                    Log.e(TAG, "******************************** Carte chargée");
                                    map.getOperationalLayers().stream().forEach(layer -> {
                                        if (layer.getLoadStatus() != LoadStatus.LOADED && layer.getLoadStatus() != LoadStatus.LOADING)
                                            // On force le chargement de tous les layers
                                            layer.loadAsync();
                                            Log.e(TAG, "******************************** Chargement du layer " + layer.getName());
                        map.loadAsync();
                    else{
                }else{
                    // Log an issue if the mobile map package fails to load
                    Log.e(TAG, mapPackage.getLoadError().getMessage());
        // load the mobile map package asynchronously
        mapPackage.loadAsync();
Thanks for you help
LionelGOUBET
Hi
do
after
and it's work
