internal dynamic map service layer  cannot be displayed
962
07-10-2013 06:34 PM
Frankwang
I was following the �??helloworld�?� example to create an simple Android application.
I am able to run the helloworld successfully.
Then I changed to use the dynamic layer by following �??Add layer to map�?� example:
http://help.arcgis.com/en/arcgismobile/10.0/apis/android/help/index.html#//01190000000n000000
it runs very well too.
Then I try to use a dynamic map service that is published in our Intranet. The map service published by our ArcGIS server 10.
On the cell phone, I set up the VPN, and then I am able to use browser to go to localserver'>http://localserver/arcgis/rest/services/campus/MapServer  directory and open the map service in javescript viewer.
The issue is:
If I used this map service to replace the map service in �??Add layer to map�?� example, my Samsung Galaxy S2 doesn�??t display this layer at all. My code looks like below:
private MapView map = null;
String dynamicMapURL = "http://localserver/ArcGIS/rest/services/Campus/MapServer";
// Retrieve the map from XML layout
map = (MapView) findViewById(R.id.map);
// Add dynamic layer to MapView
ArcGISDynamicMapServiceLayer dynamicLayer = new ArcGISDynamicMapServiceLayer(
    dynamicMapURL);
map.addLayer(dynamicLayer);
My cell phone is:  Samsung Galaxy S2
Any idea what may cause this problem?
Frank
