IllegalArgumentException: No view found for id for fragment
5733
02-22-2016 02:58 AM
tulasamirji1
I'm currently having a crash on my app which I could only detect with Crashlytics that has this stack:
Geometry Sample | ArcGIS for Developers
02-22 16:27:33.351  29321-29321/com.arcgis.android.samples.geometrysample E/AndroidRuntime﹕ FATAL EXCEPTION: main
    Process: com.arcgis.android.samples.geometrysample, PID: 29321
    java.lang.IllegalArgumentException: No view found for id 0x7f08000c (com.arcgis.android.samples.geometrysample:id/sample_fragment) for fragment BufferFragment{1ba20fbb #1 id=0x7f08000c}
            at android.support.v4.app.FragmentManagerImpl.moveToState(FragmentManager.java:1018)
            at android.support.v4.app.FragmentManagerImpl.moveToState(FragmentManager.java:1207)
            at android.support.v4.app.BackStackRecord.run(BackStackRecord.java:738)
            at android.support.v4.app.FragmentManagerImpl.execPendingActions(FragmentManager.java:1572)
            at android.support.v4.app.FragmentManagerImpl$1.run(FragmentManager.java:493)
            at android.os.Handler.handleCallback(Handler.java:739)
            at android.os.Handler.dispatchMessage(Handler.java:95)
            at android.os.Looper.loop(Looper.java:135)
            at android.app.ActivityThread.main(ActivityThread.java:5930)
            at java.lang.reflect.Method.invoke(Native Method)
            at java.lang.reflect.Method.invoke(Method.java:372)
            at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1405)
            at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1200)
help me
AlexanderNohe1
Honored Contributor
Were you using the sample that you included at the top of this stacktrace when the crash occurred?
