How to use a Closest Facilities on Android v.100.1.0
2092
6
07-14-2017 04:37 AM
VictorGallego1
I am testing the sample code of ClosestFacilityTask| arcgis-android and I can not make it work. I'd appreciate your help. For example:
// create ClosestFacilityTask instances
 mClosestFacilityTask
= new ClosestFacilityTask(context, "http://www.yourserver.com/arcgis/rest/services/NetworkAnalysis/CA/NAServer/Closest%20Facility");
// get default parameters
final ListenableFuture paramsFuture = sClosestFacilityTask.createDefaultParametersAsync(); (I guess it's a syntax error)
 paramsFeature
.addDoneListener(new Runnable() {
@Override
public void run() {
try {
       mClosestFacilityParameters
= paramsFuture.get(); (Return Object [] when mClosestFacilityParameters is a ListenableFuture?)
// add your Facility
List facilities = mClosestFacilityParameters.getFacilities(); (Cannot resolve method)
       facilities
.add(new Facility(new Point(-13045663.744, 4039204.580, WEB_MERCATOR)));
// add your Incident
List incidents = mClosestFacilityParameters.getIncidents(); (Cannot resolve method)
       incidents
.add(new Incident(new Point(-13052490.008, 4035542.739, WEB_MERCATOR)));
// solve
final ListenableFuture resultFuture = mClosestFacilityTask.solveClosestFacilityAsync(mClosestFacilityParameters);
       resultFuture
@Override
public void run() {
try {
// get ClosestFacilityRoute by facility and incident indexes
ClosestFacilityResult result = resultFuture.get(); (Gives an error because it requires a ClosestFacilityResult and get () returns an Object)
             mClosestFacilityRoute
= result.getRoute(0, 0);
} catch (Throwable e) {
Log.e(e);
Log.e(e);
Thanks!!
AlexanderNohe1
Honored Contributor
private void closestFacilities() {
        mClosestFacilityTask = new ClosestFacilityTask(getApplicationContext(), "http://www.yourserver.com/arcgis/rest/services/NetworkAnalysis/CA/NAServer/Closest%20Facility");
        final SpatialReference WEB_MERCATOR = SpatialReferences.getWebMercator();
        final ListenableFuture<ClosestFacilityParameters> paramsFuture = mClosestFacilityTask.createDefaultParametersAsync();
        paramsFuture.addDoneListener(new Runnable() {
            @Override
            public void run() {
                try {
                    mClosestFacilityParameters = paramsFuture.get();
                    List facilities = new ArrayList<Facility>();
                    facilities.add(new Facility(new Point(-13045663.744, 4039204.580, WEB_MERCATOR)));
                    mClosestFacilityParameters.setFacilities(facilities);
                    List incidents = new ArrayList<Incident>();
                    incidents.add(new Incident(new Point(-13052490.008, 4035542.739, WEB_MERCATOR)));
                    mClosestFacilityParameters.setIncidents(incidents);
                    // solve
                    final ListenableFuture<ClosestFacilityResult> resultFuture = mClosestFacilityTask.solveClosestFacilityAsync(mClosestFacilityParameters);
                    resultFuture.addDoneListener(new Runnable() {
                        @Override
                        public void run() {
                            try {
                                ClosestFacilityRoute mClosestFacilityRoute = result.getRoute(0, 0);
                                Log.e("Facility", e.toString());
You will need to use your own network data service but this should be a more concise sample.
I hope this helps!
VictorGallego1
Thanks for the reply. It has helped me.
I have another question. I have tried to do the example on a ServiceFeatureLayer with several points.
I have replaced:
by:
QueryParameters queryParams = new QueryParameters();
queryParams.setWhereClause("1=1");
queryParams.setReturnGeometry(true);
mClosestFacilityParameters.setFacilities(serviceFeatureTableX, queryParams);
When I do the method result.getRoute(0,0) returned NULL.
Any ideas?
Thanks!
AlexanderNohe1
Honored Contributor
Did you call :
serviceFeatureTableX.loadAsync()
I believe the table may need to be loaded before you can query it (not 100% on that)
VictorGallego1
It's a little weird. When I make a query that returns one result there is no problem. But if in the where clause I put "1 = 1" to return all results is when it returns null in "result.getRoute(0,0)".
I have tried serviceFeatureTableX.loadAsync() but it does not solve my problem.
Anyway thanks a lot for your quick reply
AlexanderNohe1
Honored Contributor
Interesting...
When I get more time to test, I will return to this issue.
AlexanderNohe1
Honored Contributor
How many results are being returned from your query?
