How to enter Route_World service with token
1133
07-28-2017 01:13 AM
AlanEndersoy1
Hello, I am trying to use the Route_World service but I am not able to get my credentials in the RouteTask I believe.
My code is below, I have tried to use UserCredential to bind with the task. I have not entered my temporary token anywhere? Can anyone help me to setup? Thanks
public void setupRouteTask() {
    mRouteTask = new RouteTask(getApplicationContext(), routeTaskURL);
    UserCredential userCredential =
            new UserCredential(getApplicationContext().getResources().getString(R.string.arcgis_username),
                    getApplicationContext().getResources().getString(R.string.arcgis_password));
    mRouteTask.setCredential(userCredential);
    System.out.println(userCredential.);
    final ListenableFuture<RouteParameters> listenableFuture = mRouteTask.createDefaultParametersAsync();
    listenableFuture.addDoneListener(new Runnable() {
        @Override
        public void run() {
            try {
                if (listenableFuture.isDone()) {
                    int i = 0;
                    mRouteParams = listenableFuture.get();
                    // create stops
                    Stop stop1 = new Stop(new Point(28.973663, 41.014551, SpatialReferences.getWgs84()));
                    Stop stop2 = new Stop(new Point(28.968492, 41.017619, SpatialReferences.getWgs84()));
                    List<Stop> routeStops = new ArrayList<>();
                    // add stops
                    routeStops.add(stop1);
                    routeStops.add(stop2);
                    mRouteParams.setStops(routeStops);
                    // set return directions as true to return turn-by-turn directions in the result of getDirectionManeuvers().
                    mRouteParams.setReturnDirections(true);
                    // solve
                    RouteResult result = mRouteTask.solveRouteAsync(mRouteParams).get();
                    final List routes = result.getRoutes();
                    mRoute = (Route) routes.get(0);
                    // create a mRouteSymbol graphic
                    Graphic routeGraphic = new Graphic(mRoute.getRouteGeometry(), mRouteSymbol);
                    // add mRouteSymbol graphic to the map
                    mGraphicsOverlay.getGraphics().add(routeGraphic);
                    // get directions
                    // NOTE: to get turn-by-turn directions Route Parameters should set returnDirection flag as true
                    final List<DirectionManeuver> directions = mRoute.getDirectionManeuvers();
                    String[] directionsArray = new String[directions.size()];
                    for (DirectionManeuver dm : directions) {
                        directionsArray[i++] = dm.getDirectionText();
                    System.out.println("route: " + directionsArray.toString());
            } catch (Exception e) {
                Log.e("xd", e.getMessage());
AlexanderNohe1
Honored Contributor
I would try calling mRouteTask.loadAsync() after setting your credentials.  I believe this should go out and fetch an updated token for you to finish execution.  Additionally, I have a feeling that credentials are case sensitive.  Can you match your username to how it appears in portal / arcgis online?
