hello , How Can I hide an object of type ArcGISDynamicMapServiceLayer ?? I
8029
22
11-14-2014 09:13 AM
LourdesOlvera
I used : dynamicLayer.setVisible(false);  but does not work.
this is my code:
public void solar(View button){
  String dynamicMapURL = "http://iner.energia.gob.mx:6080/arcgis/restp/services/INER/SOLAR_GLOBAL/MapServer";
  ArcGISDynamicMapServiceLayer dynamicLayer = new ArcGISDynamicMapServiceLayer(
  dynamicMapURL);
  dynamicLayer.setVisible(true);
  if(geocap.getVisibility()==View.GONE){
  geocap.removeAllViews();
      geocap.setVisibility(View.VISIBLE);
      solar();
  }else{
  geocap.setVisibility(View.GONE);
LourdesOlvera
hello, thank you very much for attending my questions, and I could fix the maps look in the API and gave me the solution. Now I have another problem, I'm making a "AsyncTask" to bring a query, but when running my program gives me this error:
12-06 10:36:50.937: E/AndroidRuntime(11225): FATAL EXCEPTION: AsyncTask #5
12-06 10:36:50.937: E/AndroidRuntime(11225): java.lang.RuntimeException: An error occured while executing doInBackground()
12-06 10:36:50.937: E/AndroidRuntime(11225): at android.os.AsyncTask$3.done(AsyncTask.java:299)
12-06 10:36:50.937: E/AndroidRuntime(11225): at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:352)
12-06 10:36:50.937: E/AndroidRuntime(11225): at java.util.concurrent.FutureTask.setException(FutureTask.java:219)
12-06 10:36:50.937: E/AndroidRuntime(11225): at java.util.concurrent.FutureTask.run(FutureTask.java:239)
12-06 10:36:50.937: E/AndroidRuntime(11225): at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:230)
12-06 10:36:50.937: E/AndroidRuntime(11225): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1080)
12-06 10:36:50.937: E/AndroidRuntime(11225): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:573)
12-06 10:36:50.937: E/AndroidRuntime(11225): at java.lang.Thread.run(Thread.java:841)
12-06 10:36:50.937: E/AndroidRuntime(11225): Caused by: java.lang.NoClassDefFoundError: com.esri.core.tasks.ags.query.Query
12-06 10:36:50.937: E/AndroidRuntime(11225): at com.example.tablaanalisis.MainActivity$QueryTable.doInBackground(MainActivity.java:214)
12-06 10:36:50.937: E/AndroidRuntime(11225): at com.example.tablaanalisis.MainActivity$QueryTable.doInBackground(MainActivity.java:1)
12-06 10:36:50.937: E/AndroidRuntime(11225): at android.os.AsyncTask$2.call(AsyncTask.java:287)
12-06 10:36:50.937: E/AndroidRuntime(11225): at java.util.concurrent.FutureTask.run(FutureTask.java:234)
12-06 10:36:50.937: E/AndroidRuntime(11225): ... 4 more
In my project I have imported "ArcGIS for Android 10.2.3" with all its libraries ... That I can do?
MengyiGuo
I found this error:
I would suggest try com.esri.core.tasks.ags.query.Query instead of Query in your definition.
LourdesOlvera
THIS IS MY CODE :
public void consultar (View button) {
  dato1=sp_Entidad_Estatal.getSelectedItem().toString();
  dato2=sp_Tipo_Energia.getSelectedItem().toString();
  if ("Jalisco".equals(dato1) && "Eólica".equals(dato2)) {
             String[ ] parametros = {servidor_URL , "ESTADO='"+dato1+"' AND ENERGIA='"+dato2+"'"};
                                //String [] queyParms = {[0],[1]} [url],[consulta]
             // QueryTable objeto = new QueryTable();
            //objeto.execute(parametros);
         new  QueryTable().execute(parametros);
  } else {
  Toast toast2 = Toast.makeText(MainActivity.this, "NO SON LOS DATOS" , Toast.LENGTH_LONG);
              toast2.show();
  } // fin else
  } //fin de metodo consultar
  private class QueryTable extends AsyncTask <String, Void, FeatureSet> {
  int caso ;
         @Override                   //Resultado
         protected FeatureSet doInBackground (String... parametros) {
        if (parametros == null || parametros.length <= 1)
      return null;
         String url = parametros[0];          // esto es targetServerURL
         String whereClause = parametros[1];
                 if (url == servidor_URL) {
                 Toast toast2 = Toast.makeText(MainActivity.this, "HAY DATOS" , Toast.LENGTH_LONG);
                   toast2.show();
         } else {
        Toast toast2 = Toast.makeText(MainActivity.this, "NO HAY DATOS" , Toast.LENGTH_LONG);
                    toast2.show();
         Query query = new Query();
        SpatialReference sr = SpatialReference.create(102100);
        query.setOutSpatialReference(sr);
        query.setReturnGeometry(true);
        String[] outfields = new String[] { "*" };
        query.setOutFields(outfields);
        query.setWhere(whereClause);
        QueryTask qTask = new QueryTask(url);
        FeatureSet fs = null;
        try {
        fs = qTask.execute(query);
        } catch (Exception e) {
        System.out.println(e.getMessage());
        return fs;
         }//fin de doInBackground
         protected void onPostExecute(FeatureSet resultado) {
        if (resultado != null) {
     Graphic [] grs = resultado.getGraphics();
     if (grs.length > 0) {
     System.out.println(resultado);
    // String poi_name = (String) gr.getAttributeValue("NAME");
     } // fin de if (grs.length > 0)
     } // fin if (resultado != null)
         } //fin de onPostExecut
  } // fin de AsyncTask
} // fin de MainActivity
--> It is a test of any query ,
MengyiGuo
change it  to
com.esri.core.tasks.ags.query.Query query = new Query();
LourdesOlvera
Hi , I try this :
com.esri.core.tasks.ags.query.Query qParameters = new Query();
com.esri.core.tasks.ags.query.QueryTask qTask = new QueryTask(url);
com.esri.core.map.FeatureSet resultado = qTask.execute(qParameters);
because this classes caused error in the code . this is the result :
12-09 12:53:03.728: D/libEGL(29724): loaded /vendor/lib/egl/libEGL_adreno.so
12-09 12:53:03.728: D/libEGL(29724): loaded /vendor/lib/egl/libGLESv1_CM_adreno.so
12-09 12:53:03.748: D/libEGL(29724): loaded /vendor/lib/egl/libGLESv2_adreno.so
12-09 12:53:03.748: I/Adreno-EGL(29724): <qeglDrvAPI_eglInitialize:316>: EGL 1.4 QUALCOMM build:  (CL4169980)
12-09 12:53:03.748: I/Adreno-EGL(29724): OpenGL ES Shader Compiler Version:17.01.10.SPL
12-09 12:53:03.748: I/Adreno-EGL(29724): Build Date: 12/01/13 Sun
12-09 12:53:03.748: I/Adreno-EGL(29724): Local Branch:
12-09 12:53:03.748: I/Adreno-EGL(29724): Remote Branch:
12-09 12:53:03.748: I/Adreno-EGL(29724): Local Patches:
12-09 12:53:03.748: I/Adreno-EGL(29724): Reconstruct Branch:
12-09 12:53:03.818: D/OpenGLRenderer(29724): Enabling debug mode 0
12-09 12:53:15.329: W/dalvikvm(29724): VFY: unable to find class referenced in signature (Lcom/esri/core/map/FeatureSet;)
12-09 12:53:15.329: E/dalvikvm(29724): Could not find class 'com.esri.core.tasks.ags.query.Query', referenced from method com.example.tablaanalisis.MainActivity$AsyncQueryTask.doInBackground
12-09 12:53:15.329: W/dalvikvm(29724): VFY: unable to resolve new-instance 1143 (Lcom/esri/core/tasks/ags/query/Query;) in Lcom/example/tablaanalisis/MainActivity$AsyncQueryTask;
12-09 12:53:15.329: D/dalvikvm(29724): VFY: replacing opcode 0x22 at 0x000b
12-09 12:53:15.329: I/dalvikvm(29724): Could not find method com.esri.core.map.FeatureSet.getGraphics, referenced from method com.example.tablaanalisis.MainActivity$AsyncQueryTask.onPostExecute
12-09 12:53:15.329: W/dalvikvm(29724): VFY: unable to resolve virtual method 9278: Lcom/esri/core/map/FeatureSet;.getGraphics ()[Lcom/esri/core/map/Graphic;
12-09 12:53:15.329: D/dalvikvm(29724): VFY: replacing opcode 0x6e at 0x0002
12-09 12:53:15.329: E/dalvikvm(29724): Could not find class  'com.esri.core.map.FeatureSet', referenced from method com.example.tablaanalisis.MainActivity$AsyncQueryTask.onPostExecute
12-09 12:53:15.329: W/dalvikvm(29724): VFY: unable to resolve check-cast 1142 (Lcom/esri/core/map/FeatureSet;) in Lcom/example/tablaanalisis/MainActivity$AsyncQueryTask;
12-09 12:53:15.329: D/dalvikvm(29724): VFY: replacing opcode 0x1f at 0x0000
12-09 12:53:15.329: D/dalvikvm(29724): DexOpt: unable to opt direct call 0x243f at 0x0d in Lcom/example/tablaanalisis/MainActivity$AsyncQueryTask;.doInBackground
12-09 12:53:15.329: D/dalvikvm(29724): DexOpt: unable to opt direct call 0x2444 at 0x2d in Lcom/example/tablaanalisis/MainActivity$AsyncQueryTask;.doInBackground
12-09 12:53:15.329: W/dalvikvm(29724): threadid=15: thread exiting with uncaught exception (group=0x415668b0)
12-09 12:53:15.339: E/AndroidRuntime(29724): FATAL EXCEPTION: AsyncTask #5
12-09 12:53:15.339: E/AndroidRuntime(29724): java.lang.RuntimeException: An error occured while executing doInBackground()
12-09 12:53:15.339: E/AndroidRuntime(29724): at android.os.AsyncTask$3.done(AsyncTask.java:299)
12-09 12:53:15.339: E/AndroidRuntime(29724): at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:352)
12-09 12:53:15.339: E/AndroidRuntime(29724): at java.util.concurrent.FutureTask.setException(FutureTask.java:219)
12-09 12:53:15.339: E/AndroidRuntime(29724): at java.util.concurrent.FutureTask.run(FutureTask.java:239)
12-09 12:53:15.339: E/AndroidRuntime(29724): at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:230)
12-09 12:53:15.339: E/AndroidRuntime(29724): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1080)
12-09 12:53:15.339: E/AndroidRuntime(29724): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:573)
12-09 12:53:15.339: E/AndroidRuntime(29724): at java.lang.Thread.run(Thread.java:841)
12-09 12:53:15.339: E/AndroidRuntime(29724): Caused by: java.lang.NoClassDefFoundError: com.esri.core.tasks.ags.query.Query 12-09
12:53:15.339: E/AndroidRuntime(29724): at com.example.tablaanalisis.MainActivity$AsyncQueryTask.doInBackground(MainActivity.java:111) 12-09 12:53:15.339: E/AndroidRuntime(29724): at com.example.tablaanalisis.MainActivity$AsyncQueryTask.doInBackground(MainActivity.java:1)
12-09 12:53:15.339: E/AndroidRuntime(29724): at android.os.AsyncTask$2.call(AsyncTask.java:287)
12-09 12:53:15.339: E/AndroidRuntime(29724): at java.util.concurrent.FutureTask.run(FutureTask.java:234)
12-09 12:53:15.339: E/AndroidRuntime(29724): ... 4 more
please help me , I do not know what is wrong ...
MengyiGuo
May I verify the ArcGIS Runtime SDK version?
LourdesOlvera
is ArcGis for Android 10.2.3
use the same SDK and the same method for other queries.
MengyiGuo
com.esri.core.tasks.ags.query.QueryTask is deprecated in 10.2.4 and the replacement should be com.esri.core.tasks.query.QueryTask.
QueryTask | ArcGIS Android 10.2.4 API
Notice that execute method asks for a different parameter in the two class. It should work if you are using ArcGIS Runtime SDK 10.2.3 but maybe not 10.2.4. I'm not sure if the issue is caused by this but I see the error message:
"Caused by: java.lang.NoClassDefFoundError: com.esri.core.tasks.ags.query.Query 12-09"
Maybe try QueryParameters instead of Query, and use queryTask.execute(QueryParameters) method for query.
And double check your query parameters since you mentioned the same code works.
// Define a new query and set parameters
QueryParameters mParams = new QueryParameters();
mParams.setWhere(whereClause);
mParams.setReturnGeometry(true);
// Define the new instance of QueryTask
QueryTask queryTask = new QueryTask(mFeatureServiceURL);
FeatureResult results;
try {
// run the querytask
results = queryTask.execute(mParams);
return results;
{ e.printStackTrace(); } return null;
LourdesOlvera
you suggest to change to 10.2.4 and classes remain this way:
- com.esri.core.tasks.query.QueryTask
- com.esri.core.tasks.query.QueryParameters
- com.esri.core.map.FeatureSet
These classes I saw on "Android 10.2.4 ArcGIS API".
Indeed queryQuery was replaced in 10.2.4 by QueryTask
LourdesOlvera
not work .... now change to 10.2.4 and wrote the classes as referenced in the API ...
com.esri.core.tasks.query.QueryParameters qParameters = new com.esri.core.tasks.query.QueryParameters ();
com.esri.core.tasks.query.QueryTask qTask = new com.esri.core.tasks.query.QueryTask(url);
com.esri.core.map.FeatureResult resultado com.esri.core.map.FeatureResult ();
the result :
12-09 18:15:48.831: E/dalvikvm(27117): Could not find class 'com.esri.core.tasks.query.QueryParameters', referenced from method com.example.tablaanalisis.MainActivity$AsyncQueryTask.doInBackground
12-09 18:15:48.831: E/dalvikvm(27117): Could not find class 'com.esri.core.map.FeatureResult', referenced from method com.example.tablaanalisis.MainActivity$AsyncQueryTask.onPostExecute
12-09 18:15:48.841: E/AndroidRuntime(27117): Caused by: java.lang.NoClassDefFoundError: com.esri.core.tasks.query.QueryParameters
