GeoDatabase
2851
7
07-18-2017 03:30 AM
JohnMcoy
Hello community, I have a question about the geodatabase. So I have a .geodatabase file containing from 33 tables, each table has different columns and field values. I'm creating an Android app and want to get the right values from the selected table. How can I achieve it ?
JohnMcoy
Any ideas ?  I think I have to use queryFeaturesAsync. At he moment I have this code :
final Geodatabase geodatabase = new Geodatabase(geodatabaseFilePath);
        geodatabase.addDoneLoadingListener(new Runnable() {
            @Override
            public void run() {
                FeatureTable featureTable = geodatabase.getGeodatabaseFeatureTable("TABLE_NAME");
                featureTable.getFields();
        geodatabase.loadAsync();
AlexanderNohe1
Honored Contributor
That looks correct to me.  You can also use getGeodatabaseFeatureTables() Geodatabase| arcgis-android  to get the information on which tables are available.
JohnMcoy
No, I don`t get, the  table values.
AlexanderNohe1
Honored Contributor
You don't get the tables or the data the tables hold?
JohnMcoy
I didn`t get both...
JohnMcoy
I do not understand how to get all the tables, and then pick up the required values
JohnMcoy
final Geodatabase geodatabase = new Geodatabase(geoDatabaseFilePath);
            @Override
            public void run() {
                for (GeodatabaseFeatureTable geoDbTable : geodatabase.getGeodatabaseFeatureTables()){
                     //How to finish here ??
