FeatureLayer in a Scene. The z-value has no effect.
2005
6
10-13-2017 04:52 AM
CarlosLópez_Moyano
I have loaded a featurelayer into a Scene but the features are always drawn on the surface. The z-values has no effect.
What i have to do?
Regards.
AlexanderNohe1
Honored Contributor
Have you set a base surface?
CarlosLópez_Moyano
Yes, i have tested it with and without base surface and i always the same result. The featureservice i try to add is this one:
http://serverportal104.esri.es/arcgis/rest/services/pruebas/PlantasEsriConCota/FeatureServer/0
If i add this featureservice to a scene viewer i can see it with z-values but i have not been  able to
obtain the same result with android sdk.
Regards
AlexanderNohe1
Honored Contributor
That feature service does not look to be publicly available.  Do you have a public feature service I can test with?
CarlosLópez_Moyano
AlexanderNohe1
Honored Contributor
I am fairly confident I know what might be occurring here.  Let me check with my colleagues to confirm what I am seeing
AlexanderNohe1
Honored Contributor
Hi Carlos López Moyano‌,
After doing some research, and speaking with some of my colleagues, we are aiming to support elevation modes in the next release (update 2).  At the moment we only draw draped features in a scene.  In update 2 you will be able to elevate with the Z value.
I hope this helps!
