Failed to resolve: com.esri.arcgisruntime:arcgis-android:100.0.0
10256
9
02-10-2017 12:37 PM
BenDempsey1
I am trying to follow the instructions in this beginner's guide, and I have added the maven url to the repositories block of the project's build.gradle, and I've put
compile 'com.esri.arcgisruntime:arcgis-android:100.0'
in the dependencies block of the app module's build.gradle.
My issue comes from when I attempt to do a gradle build, it says
is there something wrong with that dependency or what could be causing this error?
ShellyGill1
Hi Ben,
It looks like there's just a typo in your compile statement above - you should specify the full version number '100.0.0'.
Hope this helps,
Shelly
AlejandroPallares
I'm having the same issues as Ben however even after changing the version to 100.0.0 the error keeps showing.
AlexanderNohe1
Honored Contributor
Are you able to visit this url in your browser:
http://esri.bintray.com/arcgis/
Is it possible that your company cannot reach bintray via firewall or proxy settings?
AlejandroPallares
I already fixed it, and you're right it was a problem with the firewall.
Turns out Android Studio didn't updated my gradle.properties when i changed the proxy password. I could access the site in my browser, but the graddle file couldn't because it had the old password.
AlexanderNohe1
Honored Contributor
Nice!  I am glad that you were able to resolve it by updating your proxy information in gradle.
Mariagomez1
Hi Alexander Nohe and Alejandro Pallares, I encountered with the same problem .firewall is off and I have access to the mentioned website (http://esri.bintray.com/arcgis/) I am using proxy to get internet. I am new in android development, can you  please describe more how should I update gradle.properties? apparently I have the problem of updating proxy information in gradle.but i did not understand what do you mean "proxy information" and where should I get them and how to set in gradle?
Thanks in advance. I spend long time to solve this problem. I really appreciate it if you help me.
AlexanderNohe1
Honored Contributor
Hi Maria gomez‌,
This stack overflow answer may help you:
android - How to set proxy server for gradle? - Stack Overflow
Additionally, here is the grade resource for this issue:
The Build Environment - Gradle User Guide Version 3.5
Alexander
Mariagomez1
Thanks Alex
Sid
You need to update the settings in settings.gradle and change repositoriesMode.set(RepositoriesMode.FAIL_ON_PROJECT_REPOS) to repositoriesMode.set(RepositoriesMode.PREFER_SETTINGS)
and finally, add maven { url 'https://esri.jfrog.io/artifactory/arcgis' } to the repositories block.
