Error Trying to Use ArcGISLocalTiledLayer
3643
03-24-2014 09:26 AM
ClaytonBluhm
I am having trouble using the ArcGISLocalTiledLayer.  I am using the latest 10.2.2 version of the ESRI SDK for Android.  I took code from the sample located  here https://developers.arcgis.com/android/sample-code/export-tile-cache/.  I am working on an application that will be disconnected from a network and needs to use its own internal maps.  For now, I thought I could use the "Export Tile Cache" sample to download maps (when the user is connected to the network), and then use the internal TPK file that is generated when off the network.  The code I took from the sample does generate a TPK file (which I will post), but when I initially try to use the file off network I get a:
EsriStatusException[code: -1001, Message:The ArcGISTiledMapServiceLayer cannot be initialized
Below is the code I am using to switch over to local during initialization:
public void onCreate(Bundle savedInstanceState) {
  super.onCreate(savedInstanceState);
               setContentView(R.layout.map_view);
  mapURL = getResources().getString(R.string.streetMapUrl);
  defaultPath = this.getFilesDir().getAbsolutePath();
  defaultPath += DEFAULT_BASEMAP_PATH;
  File f = new File(defaultPath);
  String database = null;
  if(f.exists())
   isLocalLayerVisible = true;
   database = f.getAbsolutePath();
  Intent parentIntent = getIntent();
        wgs84Ref = SpatialReference.create(SpatialReference.WKID_WGS84);
        SharedPreferences prefs = PreferenceManager.getDefaultSharedPreferences(this);
        startLocation = new Point(parentIntent.getDoubleExtra("longitude", -80.649691), parentIntent.getDoubleExtra("latitude", 28.095114));
        dataFilterDistance = prefs.getInt(SettingsActivity.pk_culling_distance_m, 0);
  // Retrieve the map and initial extent from XML layout
  mMapView = (MapView)findViewById(R.id.map);
  // Add dynamic layer to MapView
  if(!isLocalLayerVisible)
   onlineLayerId = mMapView.addLayer(new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"));
  else
   localTiledLayer = new ArcGISLocalTiledLayer(database);
   localLayerId = mMapView.addLayer(localTiledLayer);
  mGraphLayer = new GraphicsLayer();
  graphicsLayerId = mMapView.addLayer(mGraphLayer);
   mMapView.setOnStatusChangedListener(new OnStatusChangedListener() {
         private static final long serialVersionUID = 1L;
         public void onStatusChanged(Object source, STATUS status) {
          // This is done because the project isn't setup till afterword
                           // THIS IS WHERE I SEE THE ERROR
           if (OnStatusChangedListener.STATUS.INITIALIZED == status && source == mMapView) {
            int blackColor = Color.rgb(Color.red(0),
                       Color.green(0), Color.blue(0));
         SimpleLineSymbol line = new SimpleLineSymbol(blackColor,4.0f);
         Polyline circle = createCircle(startLocation.getX(),startLocation.getY(),dataFilterDistance);
         startLocation = convertToMap(startLocation);
         filterDistanceCircle = new Graphic(circle,line);
         filterDistanceCircleUUID = mGraphLayer.addGraphic(filterDistanceCircle);
         startLocation = convertToDegrees(startLocation);
         mMapView.centerAndZoom(startLocation.getY(), startLocation.getX(), 13);
  setUpMap();
I have uploaded my TPK as a zip file.  It worries me that the error I get back is having to do with the "ArcGISTiledMapServiceLayer " which is what I am using for Remote maps.  I have verified that the code above does find the valid TPK file and skips past using my "ArcGISTiledMapServiceLayer" for online data and instantiates a "ArcGISLocalTiledLayer".
What am I doing wrong or missing?  Thanks in advance.
ClaytonBluhm
I think I have solved my problem.  It turns out in my map_view.xml (layout file) I had the following
 <com.esri.android.map.MapView
 android:id="@+id/map"
 android:layout_width="fill_parent"
 android:layout_height="fill_parent"
 mapoptions.MapType="streets"
 mapoptions.ZoomLevel="13"
 mapoptions.center="33.666354, -117.903557"/>
</com.esri.android.map.MapView>
The mapoptions don't seem to go well with the ArcGISLocalTiledLayer.  Once I removed the "mapoptions" from my layout file my maps started up fine.  The error I get back about the "Map Service" not starting leads me to believe that perhaps by having these mapoptions in the layout file the ESRI SDK tries to go off to the network even without me specifying it.
Anyway, it appears to work.  I am answer this just in case someone else stumbles upon the same problem.
