DynamicMapServiceLayer sublayers
3846
8
03-24-2017 02:28 PM
JoshBartz
I have a few interesting cases when trying to load dynamic layers with sublayers.
1) If I create a layer doing something like this:
UserCredentials credentials = new UserCredentials();
credentials.setUserAccount(uname, pword);
ArcGISDynamicMapServiceLayer serviceLayer = new ArcGISDynamicMapServiceLayer(url, int[]{parentId}, credentials);‍‍‍
For a layer with 5 sublayers, all default visible, nothing shows. So I wind up having to initialize the layer, listen for the status change, loop through the layer infos to retrieve the sublayer ids, then add a new layer to the MapView using an array containing the parent and all child IDs. On iOS using just the parent ID is sufficient.
2) If I only want 1 visible sublayer, on iOS I can pass just the ID of the sublayer. But on Android, I have to pass the parent and sublayer IDs. Am I going about this all wrong?
AlexanderNohe1
Honored Contributor
Hi Josh Bartz‌,
Do you have a sample DynamicLayer we can test with? I think for myself, I would do something like this to get all layers to show (based on the documentation):
ArcGISDynamicMapServiceLayer serviceLayer = new ArcGISDynamicMapServiceLayer(url, null, credentials);
I look forward to your reply.
Alexander
JoshBartz
Hi Alexander Nohe‌. Sorry, I should have been a bit more specific. Yes, if I use the service url with a null array, it will load all of the layers. However, take this layer for example: "original/SWPA (MapServer) "
It has a lot of layers. So if I just pass the url and a null array, it will load all of them. But if I only want Roads (ID=2) and all of its sublayers (3, 4, 5), I have to pass an array of (2, 3, 4, 5), whereas on iOS I only have to send 2. So if I don't know that the IDs of Roads' sublayers are 3, 4, 5, then I need to initialize Roads and go through the array to get the sublayer IDs.
Additionally, if I only want the Interstate Highways sublayer of roads, I have to pass (2, 3). On iOS I only have to pass 3.
I'm just trying to see if there are any other options so that we can set our data up better.
Josh
AlexanderNohe1
Honored Contributor
Hi Josh Bartz‌,
Thanks for the clarification.  I will take a look into it when I get some free time and see what I can find.
Alexander
AlexanderNohe1
Honored Contributor
Hi Josh Bartz‌,
I did investigate this a bit and found the behavior that you described on Android to be replicated.  I still need to test against runtime version 100 to see the behavior there.
Alexander
JoshBartz
ANohe-esristaff‌ Have you learned anything else?
AlexanderNohe1
Honored Contributor
Sorry 9erNumber16‌,
At this time, I did not discover anything worthwhile in sharing regarding this case. I am still reviewing some notes and hope to have an update soon.
Alexander
AlexanderNohe1
Honored Contributor
Hi Josh Bartz‌,
I did something like this to only view the roads layer and sublayers contained within that parent:
public class MainActivity extends AppCompatActivity {
    MapView mapView;
    ArcGISMapImageLayer mMapImageLayer;
    SublayerList mLayers;
    ArcGISMap map;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
// inflate MapView from layout
        mapView = (MapView) findViewById(R.id.map);
// create a map with the Basemap Type topographic
        ArcGISMap map = new ArcGISMap(Basemap.Type.TOPOGRAPHIC, 27.763528, -82.543717, 6);
// create a MapImageLayer with dynamically generated map images
        mMapImageLayer = new ArcGISMapImageLayer("https://x-23.env.nm.gov/arcgis/rest/services/original/SWPA/MapServer");
        mMapImageLayer.setOpacity(0.5f);
// add world cities layers as map operational layer
        map.getOperationalLayers().add(mMapImageLayer);
// set the map to be displayed in this view
        mapView.setMap(map);
        map.loadAsync();
        mMapImageLayer.loadAsync();
        mMapImageLayer.addDoneLoadingListener(new Runnable() {
            @Override
            public void run() {
                // get the layers from the map image layer
                mLayers = mMapImageLayer.getSublayers();
//This is the line where the error occurs
                for(ArcGISSublayer sub : mLayers) {
                    sub.setVisible(false);
                mLayers.get(2).setVisible(true);
I hope this helps!
Alexander
JoshBartz
Thanks, ANohe-esristaff‌, I'll give this a try.
