Does anyone know if there is such thing as a white basemap ?
2856
6
08-08-2016 02:02 PM
PerlaAmbriz
AlexanderNohe1
Honored Contributor
Are you looking for a white background in the mapview or a white basemap similar to that of the dark or grey basemaps?
i.e., http://www.arcgis.com/home/item.html?id=8b3d38c0819547faa83f7b7aca80bd76
PerlaAmbriz
I was just looking for more options. I wanted a white base map. since my map is only going to be of a small campus.
AlexanderNohe1
Honored Contributor
I assume you are looking for a basemap that has nothing on it?  No features showing or anything like that on the basemap?
PerlaAmbriz
yes, correct. Do you know if there are any basemaps like this?
AlexanderNohe1
Honored Contributor
Hello Perla Ambriz
Starting in quartz you can change the background of the mapview to white.  I do not believe there is a basemap satisfying the need you are looking for exactly.
HectorBorro1
If you still want some spatial reference, the light grey basemap that Alexander mentions is probably the best way to go.  You can turn off the labels layer to get a 'cleaner' look and feel.
I've found out that the dark grey http://www.arcgis.com/home/item.html?id=25869b8718c0419db87dad07de5b02d8  produces some 'clean' and nice looking maps.
cheers!
