Coordinates transformation (To Geographic)
1851
12-16-2012 05:41 AM
AlaaB__Rasheed
Hello,
Is there a way to convert the XY coordinates of point From projected to geographic coordinating system. I found that GeometryEngine.Project(Geometry, InputSR, OutputSR) only works if you want to convert from Geographic to projected.
Can anyone help me with that ?
Thanks and regards.
DanO_Neill
Converting to/from projected and geographic coordinates is supported with the GeometryEngine.project() method.  Please share your code snippet and I will investigate the issue you are having.
NigelDsouza
Try this formula to convert meters to decimal degrees
a = (b*180)/(Math.PI*6378.1370) ;
where
a is in  decimal degrees
b is in meters
so replace b with either lat or long values and get the output.
you can get these values individually put them in a point geometry and display them on the map.
