com.esri.arcgisruntime.mapping.view.MapView.setMap Attempt to invoke virtual method on a null object reference
1759
11-19-2021 09:26 AM
ScottBing2
I am attempting to execute thecode where the error occur Kotlin sample code for Find_Route and I get the following error at line 71 in the code:    Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'void com.esri.arcgisruntime.mapping.view.MapView.setMap(com.esri.arcgisruntime.mapping.ArcGISMap)' on a null object reference.
Here is the code where the error occurs:
// create a map with the basemap
val map = ArcGISMap().apply {
// set the basemap with the vector tiled layer from a service URL
basemap = Basemap(
ArcGISVectorTiledLayer(getString(R.string.navigation_vector))
mapView.apply {
// set the map to be displayed in this view
this.map = map <<<< Error occurs here...
// set initial viewpoint to San Diego
setViewpoint(Viewpoint(32.7157, -117.1611, 200000.0))
// ensure the floating action button moves to be above the attribution view
addAttributionViewLayoutChangeListener { _, _, _, _, bottom, _, _, _, oldBottom ->
val heightDelta = bottom - oldBottom
(directionFab.layoutParams as ConstraintLayout.LayoutParams).bottomMargin += heightDelta
mapView.graphicsOverlays.add(graphicsOverlay)
Error occurs at highlighted code in red font.
CodeDynode
I would like to suggest you please use
'mapView.map = map'
instead of
'this.map = map'.
I hope this will resolve you're the issue.
