Change map spatial reference, map not showing
1093
02-17-2023 12:12 PM
novruzjaf
Hi, I use ArcGIS Runtime SDK 100 for android. I create polygon objects on the map and log the geometry points, the points are correct. But I started sketcher editor and edited the geometry. The geometry coordinates are UTM coordinates and not correct coordinates. I use SpatialReference.getWGS84 for spatial reference and coordinates set lat, long. I tried setting Spatial reference for the map, but the maps not working spatial reference WGS84. Please help me. Thanks
Shubham_Sharma
The edited geometry from "SketchEditor.getGeometry()" has the same spatial reference as the map used in the MapView. To set your map to WGS84:
ArcGISMap map = new ArcGISMap(SpatialReferences.getWgs84());
map.setBasemap(new Basemap(BasemapStyle.ARCGIS_DARK_GRAY));
To convert the spatial reference of geometry to match the spatial reference of the MapView,
Geometry projectedGeometry = GeometryEngine.project(geometry, mapView.getSpatialReference());
Check out the Sketch editorSet map spatial reference, and GeometryEngine.Project
