Cannot create route from one point to another ArcGIS Android
3991
01-29-2016 08:54 PM
ImranHakeem
I've been trying very hard to create a route between two points(startPoint, endPoint). But i am getting the following error:
Location "Location 1" in "Stops" is unlocated. Location "Location 2" in "Stops" is unlocated. Need at least 2 valid stops. "Stops" does not contain valid input for any route.
My code can be found in this link: http://paste.ubuntu.com/14728671/
I've searched the internet. Many developers were/are facing this problem. I've tried all the solutions but none of them worked. I got routeTaskURL from the ArcGIS Routing Sample app. The link which is given in the documentation of ArcGIS maps gives me the 403 error if i open it in the browser.
Note: "token" and "clientID" is declared in the first step and they both are taken from the ArcGIS developers console where i registered my application.
Any Suggestions?
AlexanderNohe1
Honored Contributor
I think your coordinates are backwards.
Point(36.793653, -119.866896)
should be Point(x, y)
If you are working in WGS 84 (4326) the maximum value for Y is 90/-90.
I believe what you meant to put was:
Point(-119.866896, 36.793653)
If you add the stop graphics to your map, do they show in the correct location?
AlexanderNohe1
Honored Contributor
ImranHakeem
Thanks, i forgot to post my solution here as i posted my problem on 3 different forums and someone solved my problem.
Yes, my x and y values were switched
Thanks!
