ArcGISDynamicMapServiceLayer PNG32
1270
11-08-2013 09:44 AM
RudolfKopriva1
In the API 10.1 the Dynamic Layer export operation seems to be called with PNG format. I need to call it with PNG32. Can I set the default format in the code or can I configure the service so it will always return PNG32?
I see there are changes in the API 10.2, the format is changed when the service has 'supportsDynamicLayers' set to true. How is it related with the format?
ErwinSoekianto
Esri Alum
Why do you need PNG32 specifically?
If you want to set transparency, you can use SetOpacity()
RudolfKopriva1
The server seems to set the opacity automatically when the export is called with PNG32, see the difference in attache image.
How can I get the correct opacity value for the layer?
Thank you.
