Android SDK: can't open map in emulator
6524
8
05-14-2013 04:35 AM
MariusGächter
Dear all,
I have an app with one activity, which contains a viewflipper with multiple "subviews".
the app runs like a charm in the emulator until I open the "subview" with the MapView.
I get the following error:
FATAL EXCEPTION: GLThread 78
java.lang.IllegalArgumentException: No configs match configSpec
at com.esri.android.map.MapSurface$a.chooseConfig(Unknown Source)
at android.opengl.GLSurfaceView$EglHelper.start(GLSurfaceView.java:1024)
at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1401)
at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1240)
Thanks for your help.
Cheers
EricBader
Honored Contributor
Have you read this blog about setting up the emulator?
http://blogs.esri.com/esri/arcgis/2012/05/02/arcgis-runtime-sdk-for-android-v1-1-supports-android-em...
This really helped me when I was struggling with that same issue.
EricBader
Honored Contributor
MariusGächter
Perfect, it works now.
Thank you very much eric906.
Please excuse my late reply.
Cheers leafit
PhilipKnight1
I really wish ESRI would mention this in the requirements or readme somewhere
DanO_Neill
Great point, I have made note of it.  Please don't hesitate to submit ideas like this to ArcGIS Ideas.
JosephFlynn
Bump.  Me too.  I spent a lot of time debugging this to find out that the GPU emulator stuff mentioned in the blog fixed it.
DanO_Neill
We have an emulator doc and will support x86 emulator in the upcoming 10.2 SDK release.
DiegoCostantini
Is the doc available? Cannot find it and my x86 emulator cannot open maps (10.2.3)
DanO_Neill
EMULATOR.txt file is located in the local SDK download under [arcgis-android-install-dir]/tools/EMULATOR.txt
