Android offline editor . Save button not working.
2304
08-11-2016 12:12 AM
CanDAGDELEN1
I created offline map. I will edit on the map but save button not working. I'm sure I copy the code correctly. And I hava one problem. how is click poligon on the offline map? I want to , I will click poligon later open the new page or activity. but How? Please help me
AlexanderNohe1
Honored Contributor
Which sample are you working with specifically?
If you have the map offline and you press the save, you will later need to press the sync.
In order to launch a new activity, you should build an intent and launch that.  This guide should help with that:
Starting Another Activity
Starting Another Activity | Android Developers
CanDAGDELEN1
how am I press the sync?
CanDAGDELEN1
how is press sync ?
