Add TIF file in map by RasterLayer
1816
04-01-2021 08:17 PM
zhenghanzhang
arcgis-android:100.10.0
code:
setContentView(R.layout.activity_main);
// retrieve the MapView from layout
mMapView = findViewById(R.id.mapview);
// create a raster from a local raster file
Raster raster = new Raster(Environment.getExternalStorageDirectory().getAbsolutePath() + "/tiffiles/raster-file/Shasta.tif");
// create a raster layer
final RasterLayer rasterLayer = new RasterLayer(raster);
// create a Map with imagery basemap
ArcGISMap map = new ArcGISMap(BasemapStyle.ARCGIS_IMAGERY);
// add the map to a map view
mMapView.setMap(map);
// add the raster as an operational layer
map.getOperationalLayers().add(rasterLayer);
// set viewpoint on the raster
rasterLayer.addDoneLoadingListener(() -> mMapView.setViewpointGeometryAsync(rasterLayer.getFullExtent(), 50));
 error:
java.lang.IllegalArgumentException: Parameter boundingGeometry must not be null
MarkBaird
I suspect that this is failing as there was an issue loading the raster.  The code above could be improved by checking the load status of the file before setting the view point.  In my own app, I did the following:
      rasterLayer.addDoneLoadingListener(() -> {
        // check to see if the file loaded
        if (rasterLayer.getLoadStatus() == LoadStatus.LOADED) {
          mapView.setViewpointGeometryAsync(rasterLayer.getFullExtent(), 150);
        } else {
          // it didn't load so let's examine the load errors outputting results from these methods:
          rasterLayer.getLoadError().getMessage();
          rasterLayer.getLoadError().getCause();
So output the errors to Logcat and see what is happening.
It is possible you don't have permission to read the files from your local storage...
Let me know if this helps.
Thanks
Mark
zhenghanzhang
Thanks for reply my question!I logcat the message,it shows E/getMessage:: Unlicensed feature.
As i think i need check my license
zhenghanzhang
my tif foried to deleted setLicense and got new error.
2021-04-06 10:49:03.306 17747-17747/com.example.offlinemapdemo E/getMessage:: File error.
2021-04-06 10:49:03.306 17747-17747/com.example.offlinemapdemo E/getCause:: null
my tif folder has 4 files:Shasta.tfw ;Shasta.tif ; Shasta.tif.aux.xml ;Shasta.tif.ovr。
and my app has permission to read the local  files
May I ask where the problem may be?
