Display of KML file in esri javascript from file object
2634
01-24-2023 02:26 AM
Vinay_Kumar
I need to read the KML file from the File Object and show it on the map
Raul_Jimenez
Raul_Jimenez
@Vinay_Kumar please provide more info. You are writing the the ArcGIS REST JS forum, are you using this technology? This is mainly to access ArcGIS REST/web services.
What is the File Object? Is it the KML? It is hosted in ArcGIS?
Please share as much information as you can (to help us to help you) 😉.
Vinay_Kumar
Like User will upload the KML file we need to display on the ArcGIS REST JS Map. It was not hosted in ArcGIS. Is there an alternative without hosting?
Raul_Jimenez
I think you are talking about the ArcGIS Maps SDK for JS and not ArcGIS REST JS, are you?
If that's the case, the Maps SDK which is for client-side applications (UI) with maps have a KMLLayer class you can use to load data from an external source.
Raul_Jimenez
I moved the conversation to the right forum: https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/re-display-of-kml-file-in-esri-ja...
Sorry for the inconveniences.
