Using featureOffset to return more than 5000 records from standard_geography_query
1528
08-02-2022 02:51 PM
DanielOhrenstein
Hi all,
I am trying to use standard_geography_query to return subgeographies of a country layer (e.g. the communes of a French region). There are 5121 such objects, however standard_geography_query returns maximum 5,000 results. I was therefore trying to use featureOffset to paginate the results as mentioned in the reference. However, on my second loop when I set featureOffset=5,000 (to skip over the results I already have), I get the following error:
Feature offset (5000) must be less than maximum feature limit (5000).
Why is it I cannot use featureOffset to access >5000 results in multiple iterations? Is this the expected behaviour?
Many thanks!
DanielStauning
Hi Daniel,
I don't think pagination will help here. The 5,000 Limit is a service limitation that cannot be overridden by using pagination.
There is a geography level in between regions and communes (departmentes), for example with the Esri France dataset.
https://geoenrich.arcgis.com/arcgis/rest/services/World/geoenrichmentserver/Geoenrichment/StandardGe...
You could perhaps list the departements in a region first and then the communes in each departement. Also, this 5,000 feature limit deserves to be reevaluated and possibly raised in an upcoming release.
DanielStauning
Hi Daniel,
