Trouble selecting on a date field
1691
05-25-2019 07:30 PM
JosephElfelt1
I am working with a MapServer layer that support dynamic layers.  The data is tornado damage going back a number of years.  My goal is to select only 2019 data.
This tile call displays all the data:
https://services.dat.noaa.gov/arcgis/rest/services/nws_damageassessmenttoolkit/DamageViewer/MapServe...
In order to select 2019 data I add the following dynamicLayers parameter with a definition expression:
&dynamicLayers=[{"source":{"type":"mapLayer","mapLayerId":0},"definitionExpression":"stormdate > DATE '2019-01-01'"}]
Here is the tile call with the dynamicLayers parameter added.  This call displays...nothing.
https://services.dat.noaa.gov/arcgis/rest/services/nws_damageassessmenttoolkit/DamageViewer/MapServer/export?bbox=-11767633.378559455,5058296.783799826,-9001224.450862357,3957603.5764932865&size=1131,450&dpi=96&format=png24&transparent=true&bboxSR=3857&imageSR=3857&layers=show:0&f=image&dynamicLayers=[{"source":{"type":"mapLayer","mapLayerId":0},"definitionExpression":"stormdate > DATE '2019-01-01'"}]
Where did I mess up?
JosephElfelt1
Note that I do not want to change how the data is rendered.  Instead I simply want to display a subset of the data.
RandyBurton
JosephElfelt1
Thanks but that does not solve my problem.
Adding url encoding does not let me select just the 2019 data.
