Raster layer fields not visible in map service description
1214
07-05-2012 09:57 AM
PetraStrbenac
Hi everyone,
I have a map service that was prepared based on .msd document with two layers from my sde database (one layer is polygon fc, another layer is raster dataset which has attribute table with several fields).
The problem is that raster layer fields are not visible in service description and I have no clue why this is the case. I have tried publishing this raster layer from sde, from file geodatabase, I have tried setting the raster layer default display field in mxd...but the issue remains. Can anyone help me with this problem?? I have ArcGIS Server .NET 10 with SP4
Any help would be greatly appreciated.
Petra
