Problem posting updates with FeatureServer
3386
01-24-2011 05:01 AM
RichardBetts
Im writing an feature editing application with the Flex API using FeatureServer in ArcGIS server 10. I can successfully add and delete features but am as yet unable to modify the geometry of polygon features in SDE/Oracle(10.2.0.1.0)
Heres an example of an update I'm attempting to apply with the FeatureLayer applyEdits html page in the Services Directory.
[{"geometry":{"rings":[[[202912.407817124,898446.6930849041],[215361.05189148115,898469.7675136692],[216284.0283703202,883021.4500510262],[208761.0505275416,877310.3641501195],[201758.6872185752,883944.4265298652],[202912.407817124,898446.6930849041]]],"spatialReference":{"wkid":27700}},"attributes":{"OBJECTID":1602,"ID":11}}]
And here is the error that is returned...
Underlying DBMS error [ORA-01008: not all variables bound<br/>] [TABLE_OWNER.EDIT_TABLE]
Error applying edits.
Ive tried both the applyEdits page and the updateFeatures page with the same result.
Interestingly, If I change the word "geometry" to the word "shape" in the above (the geometry column in the database is actually called SHAPE) the result claims to be successful but if I check the geometry of the feature in the database it has not infact been updated.
OBJECTID is the only not null column in the dataset. The dataset is not versioned.
I would very much appreciate any thoughts or advice.
Cheers
Richard
RaviNarayanan
RichardBetts
Thanks for your suggestion Ravi. I tried this and still could not get the edit to work.
However, I created an entirely new table on the database, registered with sde, published a new map service with feature access enabled and I am now able to edit this new layer fully (adds,updates and deletes).
Not sure what made the difference yet but I'm still looking into it.
Thanks again.
