orderByFields with geometry query parameters
1383
03-16-2020 12:06 PM
Alexander__Contractor_Schrimpf
For some reason I am unable to sort query results using the orderByFields parameter when I also pass data in the geometry query parameter. I have tried on multiple different service layers (both arcgis online and hosted internally).
Testing it here it works correctly however:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0/query?where=1%3D1&text=&...
These two query strings give the exact same results:
query?where=1%3D1&objectIds=&time=&geometry=%7B"spatialReference"%3A%7B"wkid"%3A102100%7D%2C"xmin"%3A-10726864.061925028%2C"ymin"%3A4927441.778913066%2C"xmax"%3A-10560537.088376528%2C"ymax"%3A5074200.873220565%7D&geometryType=esriGeometryEnvelope&inSR=102100&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnHiddenFields=false&returnGeometry=true&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=OBJECTID+ASC&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=0&resultRecordCount=10&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=html
query?where=1%3D1&objectIds=&time=&geometry=%7B"spatialReference"%3A%7B"wkid"%3A102100%7D%2C"xmin"%3A-10726864.061925028%2C"ymin"%3A4927441.778913066%2C"xmax"%3A-10560537.088376528%2C"ymax"%3A5074200.873220565%7D&geometryType=esriGeometryEnvelope&inSR=102100&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnHiddenFields=false&returnGeometry=true&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=OBJECTID+DESC&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=0&resultRecordCount=10&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=html
When I remove the geometry query parameter sorting works exactly as expected
query?where=1%3D1&objectIds=&time=&geometry=&geometryType=esriGeometryEnvelope&inSR=102100&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnHiddenFields=false&returnGeometry=true&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=OBJECTID+DESC&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=0&resultRecordCount=10&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=html
Here is my layer information:
  "currentVersion" : 10.7,
  "id" : 0,
  "name" : "HydroAddressPointswithQC2500RandomV7",
  "type" : "Feature Layer",
  "serviceItemId" : "0b6195a200bf49a1b47abd75f900addd",
  "displayField" : "HydroAddressID",
  "description" : "",
  "copyrightText" : "",
  "defaultVisibility" : true,
  "editingInfo" : {
    "lastEditDate" : 1584369476377
  "relationships" : [],
  "isDataVersioned" : false,
  "supportsAppend" : true,
  "supportsCalculate" : true,
  "supportsASyncCalculate" : true,
  "supportsTruncate" : true,
  "supportsAttachmentsByUploadId" : true,
  "supportsAttachmentsResizing" : true,
  "supportsRollbackOnFailureParameter" : true,
  "supportsStatistics" : true,
  "supportsExceedsLimitStatistics" : true,
  "supportsAdvancedQueries" : true,
  "supportsValidateSql" : true,
  "supportsCoordinatesQuantization" : true,
  "supportsFieldDescriptionProperty" : true,
  "supportsQuantizationEditMode" : true,
  "supportsApplyEditsWithGlobalIds" : false,
  "supportsReturningQueryGeometry" : true,
  "advancedQueryCapabilities" : {
    "supportsPagination" : true,
    "supportsPaginationOnAggregatedQueries" : true,
    "supportsQueryRelatedPagination" : true,
    "supportsQueryWithDistance" : true,
    "supportsReturningQueryExtent" : true,
    "supportsOrderBy" : true,
    "supportsDistinct" : true,
    "supportsQueryWithResultType" : true,
    "supportsSqlExpression" : true,
    "supportsAdvancedQueryRelated" : true,
    "supportsCountDistinct" : true,
    "supportsPercentileStatistics" : true,
    "supportsLod" : true,
    "supportsQueryWithLodSR" : false,
    "supportedLodTypes" : [
      "geohash"
    "supportsReturningGeometryCentroid" : false,
    "supportsQueryWithDatumTransformation" : true,
    "supportsHavingClause" : true,
    "supportsOutFieldSQLExpression" : true,
    "supportsMaxRecordCountFactor" : true,
    "supportsTopFeaturesQuery" : true,
    "supportsDisjointSpatialRel" : true,
    "supportsQueryWithCacheHint" : true
  "useStandardizedQueries" : true,
  "geometryType" : "esriGeometryPoint",
  "minScale" : 0,
  "maxScale" : 0,
  "extent" : {
    "xmin" : -177.10755675532565,
    "ymin" : 13.256663054422972,
    "xmax" : 145.92024380577055,
    "ymax" : 71.019395373096984,
    "spatialReference" : {
      "wkid" : 4269,
      "latestWkid" : 4269
  "drawingInfo":{"renderer":{"type":"simple","symbol":{"type":"esriSMS","style":"esriSMSCircle","color":[0,115,76,255],"size":10,"angle":0,"xoffset":0,"yoffset":0,"outline":{"color":[0,0,0,255],"width":0}}},"scaleSymbols":true,"transparency":0,"labelingInfo":null},
  "allowGeometryUpdates" : true,
  "hasAttachments" : false,
  "htmlPopupType" : "esriServerHTMLPopupTypeAsHTMLText",
  "hasMetadata" : true,
  "hasM" : false,
  "hasZ" : true,
  "enableZDefaults" : true,
  "zDefault" : 0,
  "objectIdField" : "OBJECTID",
  "uniqueIdField" :
    "name" : "OBJECTID",
    "isSystemMaintained" : true
  "globalIdField" : "",
  "typeIdField" : "",
  "fields" : [
      "type" : "esriFieldTypeOID",
      "alias" : "OBJECTID",
      "sqlType" : "sqlTypeOther",
      "nullable" : false,
      "editable" : false,
      "domain" : null,
      "defaultValue" : null
      "name" : "HydroAddressID",
      "type" : "esriFieldTypeString",
      "alias" : "HydroAddressID",
      "length" : 40,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "AddressDate",
      "type" : "esriFieldTypeDate",
      "alias" : "AddressDate",
      "length" : 8,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "FeatureType",
      "alias" : "FeatureType",
      "length" : 60,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "OnNetwork",
      "type" : "esriFieldTypeInteger",
      "alias" : "OnNetwork",
      "nullable" : false,
      "editable" : true,
      "domain" :
        "type" : "codedValue",
        "name" : "NoYesDomain",
        "codedValues" : [
            "name" : "No",
            "code" : 0
            "name" : "Yes",
            "code" : 1
      "name" : "SourceID",
      "alias" : "SourceID",
      "length" : 130,
      "nullable" : false,
      "editable" : true,
      "domain" : null,
      "name" : "SourceAgency",
      "alias" : "SourceAgency",
      "length" : 130,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "SourceDataset",
      "alias" : "SourceDataset",
      "length" : 130,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "SourceFeatureURL",
      "alias" : "SourceFeatureURL",
      "length" : 255,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "Catchment",
      "type" : "esriFieldTypeDouble",
      "alias" : "Catchment",
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "HU",
      "alias" : "HU",
      "length" : 16,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "ReachCode",
      "alias" : "ReachCode",
      "length" : 14,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "Measure",
      "alias" : "Measure",
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "ReachSMDate",
      "alias" : "ReachSMDate",
      "length" : 8,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "OriginalReachCode",
      "alias" : "OriginalReachCode",
      "length" : 14,
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "OriginalMeasure",
      "alias" : "OriginalMeasure",
      "nullable" : true,
      "editable" : true,
      "domain" : null,
      "name" : "OriginalRCMatch",
      "alias" : "OriginalRCMatch",
      "nullable" : true,
      "editable" : true,
      "domain" :
        "codedValues" : [
            "name" : "No",
            "code" : 0
            "name" : "Yes",
            "code" : 1
      "name" : "SnapTolerance",
      "alias" : "SnapTolerance",
      "nullable" : false,
      "editable" : true,
      "domain" : null,
      "name" : "SnapDistance",
      "alias" : "SnapDistance",
      "nullable" : false,
      "editable" : true,
      "domain" : null,
      "name" : "InSnapTolerance",
      "alias" : "InSnapTolerance",
      "nullable" : false,
      "editable" : true,
      "domain" :
        "codedValues" : [
            "name" : "No",
            "code" : 0
            "name" : "Yes",
            "code" : 1
      "name" : "QCTolerance",
      "alias" : "QCTolerance",
      "nullable" : false,
      "editable" : true,
      "domain" : null,
      "name" : "InQCTolerance",
      "alias" : "InQCTolerance",
      "nullable" : false,
      "editable" : true,
      "domain" :
        "codedValues" : [
            "name" : "No",
            "code" : 0
            "name" : "Yes",
            "code" : 1
      "name" : "QCApproved",
      "alias" : "QCApproved",
      "nullable" : false,
      "editable" : true,
      "domain" :
        "codedValues" : [
            "name" : "No",
            "code" : 0
            "name" : "Yes",
            "code" : 1
  "indexes" : [
      "name" : "PK__HYDROADD__F4B70D856D3291D3",
      "fields" : "OBJECTID",
      "isAscending" : true,
      "isUnique" : true,
      "description" : ""
      "name" : "user_3341.HYDROADDQC_HYDROADDRESSPOINTSWITHQC2500RANDOMV7_Shape_sidx",
      "fields" : "Shape",
      "isUnique" : false,
      "description" : ""
  "types" : [],
  "templates" : [
      "description" : "",
      "drawingTool" : "esriFeatureEditToolPoint",
      "prototype" : {
        "attributes" : {
          "InQCTolerance" : 0,
          "QCApproved" : 0,
          "HydroAddressID" : null,
          "AddressDate" : null,
          "FeatureType" : null,
          "OnNetwork" : 0,
          "SourceID" : " ",
          "SourceAgency" : null,
          "SourceDataset" : null,
          "SourceFeatureURL" : null,
          "Catchment" : null,
          "HU" : null,
          "ReachCode" : null,
          "Measure" : null,
          "ReachSMDate" : null,
          "OriginalReachCode" : null,
          "OriginalMeasure" : null,
          "OriginalRCMatch" : null,
          "SnapTolerance" : 0,
          "SnapDistance" : 0,
          "InSnapTolerance" : 0,
          "QCTolerance" : 0
  "supportedQueryFormats" : "JSON, geoJSON, PBF",
  "hasStaticData" : false,
  "maxRecordCount" : 2000,
  "standardMaxRecordCount" : 32000,
  "standardMaxRecordCountNoGeometry" : 32000,
  "tileMaxRecordCount" : 8000,
  "maxRecordCountFactor" : 1,
  "capabilities" : "Query"
}j
