NTLM Authorization issues
2724
11-09-2010 10:58 AM
DavidStreet
Hi, I am making calls to WCF services on IIS7. After I make a call using a REST call from the ArcGISDynamicMapServiceLayer Map Service (esri.arcgis.client.dll) I get an NTLM authorization error to any future WCF calls. Do you have any suggestions on how I can get around this?  Looking at Fiddler it seems like the Map Service is removing the NTLM data. Thank you in advance for any suggestions.
David
EricMiller1
David,
   Can you please provide a few more pieces of information?  First, have you enabled security on your services?  If so, please let us know what type.  Second, how are you accessing the service (through a firewall/DMZ, or internally). Finally, what is your local security policy setting for Network security: LAN Manager authentication level?  We recommend that it be set to "Send LM and NTLM only".
Eric Miller
Esri Product Engineer
