Mobile Tools in a GPServer
1195
05-02-2011 08:09 AM
AndrewBrown
Using ArcGIS Server 10 SP1 - Enterprised Advanced
I've published a GPService from a toolbox containing two models. One is using the create mobile map tool and the other is using synchronize mobile cache.
When I try to execute or submit job (synchronous / asynchronous) respectively, I recieve errors that the tool is invalid. Error 000816 Code 500. "The tool is invalid"
Tools can be run within ArcMap and work fine.
My mxd is on a share with the SOC account having modify permissions through share along with change permissions through NTFS security for both map and cache folders.
Toolbox is published from a different share with SOC account also having modify permissions through share and ntfs.
Does anyone know if using these Mobile Tools in a Published ArcGIS Server GPServer service is restricted or does anyone have any thoughts on why they don't execute?
Andrew
AndrewBrown
In case anyone runs across this and wants the answer.  The Mobile Toolbox tools are not intended to be published as a GPService in ArcGis Server.  The built in Mobile Synchronization and Cache creation functionality should be used.
