Labelling through SOE using Silverlight
1313
04-18-2012 05:07 AM
sameerpuppal
I had created a tool in .net adf using SOE for labelling. it was exactly the same in desktop (Label Manager)
I am trying tom replicate the same in silverlight Web application.
I have used same code from SOE to the RestSOE and trying to get labelling.
I have 2 issues :-
1. Does SOE make changes in mxd or not ?
2. complete code in the SOE is getting executed without any error but changes are not reflected. is it issue related cache or refreshing the service?
Please help!
RichardWatson
You should probably read about pooled and non-pooled map services in the help.
Note that with 10.1, non-pooled services are not supported.
TanuHoque
At 10.1, 'dynamicLayers enabled mapservice' supports defining label for a layer within a mapservice per request basis.
sameerpuppal
I have read but did not understand whether it is possible or not.
Is it that if i use pooled service then it is possible or other way around.
Don't we have anything similar to  RefreshServerObjects() in .net adf in REST?
Do we have any workaround in SOAP ?
Thanks!
Sameer
