Inverse geocoding
3759
05-01-2015 09:59 AM
FrancisMoisan
Hi!
We have a geocoding service on a road feature class and the geocoding works well to locate an adresse but when i try the "Inverse geocoding", if my coordinate is more than 10 km away from any road, I have no return from the service (rest or arcmap).  Any search distance limit on a geocoding service?
Any idea on how to manage the distance?
thank you!
TomSellsted
Francis,
If you don't specify a distance, it defaults to 100 meters.
Here is a link that might help:
ArcGIS REST API
Regards,
Tom
FrancisMoisan
Even with a distance... the limit seem to be 10 km.
Even if I write a distance of 100000 meter (100 km) There is no result returned...
I use the Canada style locator.
I will try with the USA locator style...
Francis
TomSellsted
Francis,
There might be a finite limit though the documentation doesn't show a limit.  10km does sound quite a long distance. You may have more luck using a "near" method.
Regards,
Tom
