If a raster layer in a Pro map has Layer Properties > General > Out Beyond set and that is published as a Map Service, querying the service using identify will return an empty result. Is this intentional/necessary or is this an oversight?
Steps to reproduce:
- Add a raster layer to a Pro map.
- Change the Layer Properties > General > Out Beyond on the raster layer to something like 1:10,000,000.
- Use the Publish Map Service tool to publish the map as a MapServer.
- Query the MapServer using MyServiceName/MapServer/identify.
The returned results array will always be empty. To verify, repeat the above steps except with Out Beyond set to <None> and use the same query parameters. Results will be returned.
