Cannot Add WMS Layers with REST API
1894
08-21-2019 08:39 AM
CharlesNorsworthy
I am using ESRI’s REST API to create a new Web Map with WMS layers. I am trying to run the POST request http://{{domain}}/portal/sharing/rest/content/users/{{username}}/addItem with the following in the body:
f: json
title: testMap
type: Web Map
token: {{token}}
text:
  "operationalLayers": [
      "id": "wms_3449",
      "url": "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi",
      "visibility": true,
      "visibleLayers": [
        "nexrad-n0r"
      "opacity": 1,
      "title": "IEM WMS Service",
      "layerType": "WMS",
      "version": "1.3.0",
      "mapUrl": "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi",
      "layers": [],
      "spatialReferences": [
        900913,
        4326,
        102100,
        3857
      "extent": [
          -126,
          24
          -66,
          50
      "maxWidth": 2048,
      "maxHeight": 2048
  "baseMap": {
            "baseMapLayers": [
            "id": "defaultBasemap",
            "layerType": "ArcGISTiledMapServiceLayer",
            "url": "http://services.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer",
            "visibility": true,
            "opacity": 1,
            "title": "ESRI_Imagery_World_2D"
            "spatialReference": {
            "latestWkid": 4326
Note, the WMS layer is based on the ArcGIS example using a WMS layer as an operational layer here: https://developers.arcgis.com/web-map-specification/objects/wmsLayer/ .  When I try to create this map, it initially says
    "success": true,
    "id": "<whatever the id is>",
    "folder": null
However, whenever I try to view the map using Map Viewer, I get an error message saying “The map cannot be drawn completely because one or more layers are not supported. These layers will be omitted.” From Map Viewer, when I go to Add->Add Layer from Web->A WMS OGC Web Service and put in the url from the text above, namely http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?REQUEST=GetCapabilities&SERVICE=WMS, I get the following error: The WMS service, http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi, cannot be added to the map. It is either not available or you have entered an invalid URL for the type of layer you want to reference.
When I try to add this url manually, Fiddler says I got a 403 error when ArcGIS was trying to use a proxy for this request: GET /portal/sharing/proxy?https://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?SERVICE=WMS&REQUEST=GetCapabilities HTTP/1.1
Does anyone know what is causing these errors? I appreciate any feedback.
