ArcGIS Rest API - Publishing Locator
3526
11-17-2014 01:05 PM
ErnestoCarreras3
How can the following pooling parameters be configured with python?
Under the Pooling configuration> Specify Service Timeouts
    The maximum time a client can use a service: 60 seconds
    The maximum time a client will wait to get a service: 60 seconds
    The maximum time an idle instance can be kept running: 3600 seconds
XanderBakker
Esri Esteemed Contributor
Have a look at the example which demonstrates how to modify the min and max instances for a service:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
The REST API Help to edit a service definition can be found here:
ArcGIS Server Administrator API
You're looking for:
  • maxUsageTime
  • maxWaitTime
  • maxIdleTime
Kind regards, Xander
