2000 rows limitation with api export json data
9006
07-31-2022 08:43 PM
LeahYan
Hi all. My name is Leah, I am working as a data specialist to help my team with reporting and data analysis. We have a GIS partner who built a web app for us. The web app is used for collecting data from offline environments, and it works great with our workflow. We also have a powerBI dashboard to use the data collected from this web app for reporting.
I am able to set up the Rest API with auth token to refresh the data from a feature layer, however, I can export 4200 rows from the ArcGIS online (https://<services-url>/arcgis/rest/services/<layer-name>/FeatureServer/0).
Only 2000 rows were exported if I use Rest API  (https://<services-url>/arcgis/rest/services/<layer-name>/FeatureServer/0/query?where=1%3D1&outFields=*&returnGeometry=false&resultRecordCount=0&f=json&token=token).
I followed another post https://support.esri.com/en/technical-article/000012383 to change the maxRecordCount to 8000. Even so, I still get only 2000 rows from my export json file.
Does anyone have an idea why this would be happening? Is anything I can do to export the entire dataset from a feature layer host on ArcGIS online? If not, is there any workaround for PowreBI data refreshing?
Thanks for the help!
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
Have you read the Query (Feature Service/Layer)—ArcGIS REST APIs | ArcGIS Developers documentation?  Specifically, the parts about resultType and max record count?
Raul_Jimenez
I have never been able to increase the maxRecordCount above 2000, but you have two options:
1) Use the "resultOffset" parameter (which is the pagination mechanism): <- this is the one I would recommend
2) Use the asynchronous/job "https://[root]/content/users/[userName]/export" endpoint to generate a file.
Another page that you might want to check is the Feature service page within the "Mapping APIs and locations services guide" (it is a conceptual guide about many of the cross concepts of the ArcGIS system, including the REST APIs).
I hope this helps.
AW_Grove
Hi @Raul_Jimenez - do you have an example query where you have used the resultOffset option? Below is what I am using right now, but seeing max of 2000 records. I don't see the resultOffset parameter in the query documentation so I am wondering if it is supported with this method.
ArthurSmith
Came across this limitation myself and found this thread.  Used @Raul_Jimenez 's reccomendation and used the resultOffset parameter in an ArcPy script.  Here is the code if anyone else needs to do something similar.
def Map_Service_Batch_Download(fs_url, batch_size, download_folder, out_fc):
# Get count of records in feature service and # of download batches needed
record_cnt = int(str(arcpy.management.GetCount(fs_url)))
downloads_necessary = math.ceil(record_cnt/batch_size)
# Download .geojson for each batch based on total # of records, 2000 at a time
for dl_cnt in list(range(downloads_necessary)):
start_record = dl_cnt*batch_size
urllib.request.urlretrieve(fs_url + "/query?outFields=*&where=1%3D1&f=geojson&resultOffset=" + str(start_record) + "&resultRecordCount=" + str(batch_size), dl_dir + "Weld_Parcels_DL_" + str(dl_cnt) + ".geojson")
# Loop through all the downloaded .geojsons and load to output feature class
geojson_cnt = 0
for geojson in os.listdir(download_folder):
arcpy.JSONToFeatures_conversion(download_folder + geojson, "memory/parcels_temp", "POLYGON")
if geojson_cnt == 0:
arcpy.arcpy.management.CopyFeatures("memory/parcels_temp", out_fc)
else:
arcpy.management.Append("memory/parcels_temp", out_fc)
os.remove(download_folder + geojson)
geojson_cnt += 1
Map_Service_Batch_Download(weld_parcel_url, 2000, dl_dir, parcels_from_geojson)
