ArcGIS Production Mapping Product Files 3.3.0.1 patch -- Now Available
132
08-22-2024 01:04 PM
jos20
by Esri Contributor
The ArcGIS Pro Production Mapping Product Data 3.3.0.1 is now available for download.
Description
The ArcGIS Pro Production Mapping Product Data 3.3.0.1 is now available for download from My Esri. To download Esri software, go to the My Organizations tab, then click the Downloads sub tab. You must have Download software permission in order to access the Downloads sub tab. If you do not see this sub tab, you may need to request permissions.
Notes
  • This is a full install of the Product Files which includes all updated and previously released configuration files.
  • Remove any previous version of the Production Mapping product data files before applying this patch.
  • Any edits made to configuration files should be preserved before installing this update.
Enhancements and issues addressed
  • Issue 3375—Generalization: Simplify Building tool hangs in Structure model
  • Issue 3382—Generalization: Extract by Data fails when AOI is in SDE and the user is not connected as owner
  • Issue3394— Generalization: Collapse SOE model fails if there are no SOE features selected for the collapse operation
  • Issue 3446— Generalization: Eliminate by Field Value in General Polygons needs to accept multiple attributes as dissolve field
  • Issue 3447— Generalization: If the second Thin Road Network does not run, the Roads model fails
  • Issue 3450— Generalization: Thin Buildings model fails at Simplify Building for large datasets
If you experience problems after installing this patch, please log a case with technical support.
We always welcome ideas, enhancements and suggestions on our ArcGIS Production Mapping Ideas page.
