ArcGIS Production Mapping Blog
Other Boards in This Place
Latest Activity
(52 Posts)
jos20
by Esri Contributor
Announcing the ArcGIS Production Mapping extension updates at the ArcGIS Enterprise 11.4 and ArcGIS Pro 3.4 release.
Read more...
more
1 0 188
jos20
by Esri Contributor
Originally posted 08-22-2024 01:10 PM and moved from the Questions board to the Blog board:
Announcing Production Mapping product data patch (11.3.0.1) for ArcGIS Enterprise 11.3.
Read more...
more
1 0 128
jos20
by Esri Contributor
The ArcGIS Pro Production Mapping Product Data 3.3.0.1 is now available for download.
The ArcGIS Pro Production Mapping Product Data 3.3.0.1 is now available for download from My Esri. To download Esri software, go to the My Organizations tab, then click the Downloads sub tab. You must have Download software permission in order to access the Downloads sub tab. If you do not see this sub tab, you may need to request permissions.
Notes
  • This is a full install of the Product Files which includes all updated and previously released configuration files.
  • Remove any previous version of the Production Mapping product data files before applying this patch.
  • Any edits made to configuration files should be preserved before installing this update.
Enhancements and issues addressed
  • Issue 3375—Generalization: Simplify Building tool hangs in Structure model
  • Issue 3382—Generalization: Extract by Data fails when AOI is in SDE and the user is not connected as owner
  • Issue3394— Generalization: Collapse SOE model fails if there are no SOE features selected for the collapse operation
  • Issue 3446— Generalization: Eliminate by Field Value in General Polygons needs to accept multiple attributes as dissolve field
  • Issue 3447— Generalization: If the second Thin Road Network does not run, the Roads model fails
  • Issue 3450— Generalization: Thin Buildings model fails at Simplify Building for large datasets
If you experience problems after installing this patch, please log a case with technical support.
We always welcome ideas, enhancements and suggestions on our ArcGIS Production Mapping Ideas page.
more
0 0 322
ShareUser
Esri Community Manager
Workflows have been identified that can cause inconsistencies in the branch versioning system tables. When such an issue is encountered, features with missing branch versioning metadata can cause data inconsistencies when the version is reconciled, posted, and/or deleted.
Read more...
more
0 0 176
ShareUser
ArcSDE User-Schema Geodatabases in Oracle are deprecated
Read more...
more
0 0 213
jos20
by Esri Contributor
The ArcGIS Pro 3.3 release in May included enhancements to the ArcGIS Production Mapping extension.
Learn more about the new functionalities in and out of the Topographic Production toolbox or check out this ArcGIS Blog post.
The product data at the 3.3 release is available for download from My Esri.
more
1 0 403
jos20
by Esri Contributor
The ArcGIS Pro 3.3 release in May included enhancements to the ArcGIS Defense Mapping extension.
more
0 0 347
jos20
by Esri Contributor
ArcGIS Enterprise 11.3 was released in May and with it came enhancements for the ArcGIS Production Mapping extension.
While this release mostly consisted of new capabilities in the self-serve Map Production System web app, there were also updates to the Topographic Production Service.
Visit the Enterprise what's new site for a quick list or check out this ArcGIS Blog post for detailed demonstrations.
more
0 0 335
ShareUser
Intended for database administrators as recommendations for establishing the product workspaces in an Enterprise Geodatabase (Oracle®, SQL Server®, PostgreSQL®).
Read more...
more
0 0 219
ShareUser
Mapping & Charting Solutions (MCS) Enterprise Databases Best Practices
Read more...
more
0 0 327
89 Subscribers
Labels
