I'd like to update my stand alone sql table base on values returned from my selection set. I was able to get the selection part but I couldn't find any snippets for updating sql table. Thank you for your help. Your help is greatly appreciated.
Hi Helen,
Just to clarify, when you say "stand alone sql table base" are you referring to a table in a database and not a geodatabase? That is, a database that has not been registered as a geodatabase?
--Rich
Correct it's just a sql table in database NOT a geodatabase. My end goal to to have a sql table with a common field with my feature layer and the two joined so I can label my feature layer using a field from the sql table since I'm not allowed to edit the feature layer.
Or is there a better way to achieve what I need to do? Thank you Rich.
The Pro SDK doesn't allow you to edit non-geodatabase tables. You could either add that SQL table to a geodatabase, or edit it using non-ArcGIS routines.
The easiest solution would be to register the table with a geodatabase? Is there a reason you cannot do this?
--Rich
p.s. Technically, you can also edit a non-geodatabasea table if it is published as part of a feature service, but that seems like using a sledgehammer to hang a picture frame.
Hi Rich,
I'm a little confused here so let's clarify more about my table.
Yes I can have my table live inside a geodatabase but my table is just a tabular table.
In ArcObjects for Arcmap addin, I used these codes to update a sql table doesn't matter where my table is. So you say in ProSDK I can no longer do that? Thanks Rich!
Dim sqlConnection As New SqlConnection(sConStr)
Dim cmdUpdate As New SqlCommand
cmdUpdate.Connection = sqlConnection
cmdUpdate.CommandType = CommandType.StoredProcedure
cmdUpdate.CommandText = "sp_CalculateRate"
cmdUpdate.Parameters.Add(New SqlParameter With {.ParameterName = "@ABCD", .SqlDbType = SqlDbType.VarChar, .Value = strABCD})
cmdUpdate.Parameters.Add(New SqlParameter With {.ParameterName = "@EFGH", .SqlDbType = SqlDbType.VarChar, .Value = strEFGH})
sqlConnection.Open()
cmdUpdate.ExecuteNonQuery()
cmdUpdate.Dispose()
sqlConnection.Close()
Helen,
The code you have listed, using the SqlConnection and SqlCommand classes, comes from a Microsoft library, not from ArcObjects. You can continue to use it just fine.
--Rich
