Theme and Esri Style loading issue in combobox
1224
02-10-2020 07:09 PM
by Anonymous User
Not applicable
Hi Guys,
I got style loading inconsistently in ArcGIS Pro , combobox.
For example that combobox :
Loaded correctly with the following code.
<ComboBox Background="{DynamicResource Esri_BackgroundPressedBrush}" Foreground="{DynamicResource Esri_TextStyleEmphasisBrush}" IsEditable="False" Grid.Row="0" Grid.Column="1" SelectedValue="{Binding Path=InputModel.Delimiter}" SelectedValuePath="Tag" >
                <ComboBoxItem Tag=",">Comma</ComboBoxItem>
                <ComboBoxItem Tag=" ">Space</ComboBoxItem>
                <ComboBoxItem Tag="  ">MultiSpace</ComboBoxItem>
                <ComboBoxItem Tag="\t">Tab</ComboBoxItem>
                <ComboBoxItem Tag=":">Colon</ComboBoxItem>
                <ComboBoxItem Tag="?">Other</ComboBoxItem>
            </ComboBox>
However, If I load dynamically with style edit based on mvvm binding. with same background and foreground style. I got different result.
                      Grid.Row="8" Grid.Column="1" SelectedItem="{Binding Path=InputModel.LongIndex, Mode=TwoWay}" SelectedValuePath="Tag"
                      ItemsSource="{Binding Path=ColumnCount, Mode=TwoWay}" >
                <ComboBox.Style>
                    <Style TargetType="{x:Type ComboBox}">
                        <Setter Property="IsEnabled" Value="False">
                        </Setter>
                        <Style.Triggers>
                            <DataTrigger Binding="{Binding Path=InputModel.DataReady}" Value="True">
                                <Setter Property="IsEnabled" Value="True" />
                            </DataTrigger>
                        </Style.Triggers>
                    </Style>
                </ComboBox.Style>
            </ComboBox>
Do I need something to make it work or is that bug?
Best Regards,
Than
by Anonymous User
Not applicable
Hi Guys,
Managed to get workaround without using style trigger.
I just directly bind with the properties through viewmodel, for those with visibility which is not default string format.
I create the new variable with visibility data type. That way solve for me at the moment.
                          IsEditable="False" Grid.Row="8" Grid.Column="1" SelectedItem="{Binding Path=BatchUploadModel.LatIndex}"
                          ItemsSource="{Binding Path=ColumnCount, Mode=TwoWay}" IsEnabled="{Binding Path=BatchUploadModel.DataReady}">
                        </ComboBox>
by Anonymous User
Not applicable
Hi Guys,
                        </ComboBox>
