StandaloneTable edit
2896
8
07-26-2023 12:06 PM
BrianBulla
Honored Contributor
I'm trying to update a StandaloneTable through the SDK.  It is a .dbf file, in my map at the time of running the code.  I am using ArcGIS Pro 2.9.
I am getting the error on the row.Store() line.  I have tried to update my inspFile.Search(qf) line to inspFile.Search(qf,True), but then I get a "No Overload for method Search take 2 arguments" error.  Is this just a 2.9 issue??  If so, is there some other way to update the .dbf that would work in 2.9??
StandaloneTable inspFile = map.GetStandaloneTablesAsFlattenedList().FirstOrDefault(tbl => tbl.Name == GlobalVars.HydInspFile);
QueryFilter qf = new QueryFilter();
qf.SubFields = "FACILITYID";
qf.WhereClause = "FACILITYID = '" + shpFacilityID + "'";
using (RowCursor rowCursor = inspFile.Search(qf))
       while (rowCursor.MoveNext())
             using (var row = rowCursor.Current)
                  row["FACILITYID"] = sdeFacilityID;
                  row.Store();
GKmieliauskas
Your code is very complicated. Try code below:
                var modifyTable = new ArcGIS.Desktop.Editing.EditOperation();
                modifyTable.Name = "Update HYDINSP Table";
                using (var rowCursor = inspFile.Search(qf))
                            modifyTable.Modify(row, "FACILITYID", sdeFacilityID);
                modifyTable.Execute();
Modify method help
I have made changes of your code directly in community editor and haven't tested it.
GKmieliauskas
Standalone table has different Search method parameters than Table or FeatureClass.
More info here:
https://pro.arcgis.com/en/pro-app/2.9/sdk/api-reference/index.html#topic12260.html
What type of error do you get on row Store? System.NotSupportedException or GeodatabaseException?
On ArcGIS Pro 3.1.2 your code works if Search section is included into QueuedTask.Run.
BrianBulla
Honored Contributor
Yes, it's all in a QueuedTask.Run.
The error I get is a GeodatabaseException.
So since at 2.9 the Search function doesn't really provide me a way to edit the rows, I guess that I just need to wait until we get 3.x pushed out to us by our IT department.
GKmieliauskas
Maybe your dbf file is locked somewhere else?
BrianBulla
Honored Contributor
No, the file is definitely not open by anything else.  Only being used in the Pro project.
So I'm trying this on a Pro 3.0 machine, but still getting an error on the row.Store() line.  See below.  So when you tried this on 3.1 did you make any code changes to what I have above??
GKmieliauskas
As I mentioned I have added QueuedTask.Run and changed field name corresponding my dbf file.
BrianBulla
Honored Contributor
So I got this to work in 3.0.  I'll try it in 2.9....my guess is it will work there too.
Not sure why I can't edit that table using a RowCursor though.
Anyways.....
                //Table table = inspFile.GetTable();
                var oids = new List<long>();
                            oids.Add(row.GetObjectID());
                var tableInsp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
                foreach (var oid in oids)
                    tableInsp.Load(inspFile, oid);
                    tableInsp["FACILITYID"] = sdeFacilityID;
                    modifyTable.Modify(tableInsp);
GKmieliauskas
Modify method help
BrianBulla
Honored Contributor
Yes, that is simpler.  Thanks for your help with this!
