Showing Selection Rectangle
1585
05-05-2023 08:10 AM
RussellSuter
Hi all,
I'm currently running ArcGIS Pro 3.0.2.
When I use the rectangle "Select" tool in the Maps tab, a rectangle is continuously displayed and when the pointer is in the area, there are resize boxes available:
How do I get this box in my custom tool?  My code is:
   internal class SelectByRectangleMapTool : MapTool
      public SelectByRectangleMapTool()
         IsSketchTool = true;
         CompleteSketchOnMouseUp = true;
         SketchType = SketchGeometryType.Rectangle;
         SketchOutputMode = SketchOutputMode.Map;
      protected override Task OnToolActivateAsync(bool active)
         return base.OnToolActivateAsync(active);
      protected override Task<bool> OnSketchCompleteAsync(Geometry geometry)
         return QueuedTask.Run(() =>
            ActiveMapView.SelectFeatures(geometry);
            return true;
I've tried a few resources like IsWYSIWG with no joy.  Any help is appreciated.
Wolf
by Esri Regular Contributor
Just to clarify: This behavior requires the following options setting in ArcGIS Pro:
I was not able to get this to work either, i passed the question on to team.   I will let you know what we find.
RussellSuter
Hi Wolf,
Anymore info on this question?
RussellSuter
Is this possibly an implementation of an OverlayControl?
