Show progress when running a geoprocessing
7615
12
08-30-2023 11:44 AM
HelenZhou
Hello, I am working on an ArcGIS Pro SDK project, which includes running a geoprocessing tool. This tool runs 30+ seconds. Is there a good way to show progress which the tool is running?
I have found   ArcGIS.Desktop.Framework.Threading.Tasks.ProgressDialog. https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic10965.html#i-heading-example. When I use the example code in my application, I don't see the progress dialog shows up (not in debug mode).
here is the code module -
public static async Task<bool> ProcessSpatialJoin(string target_feats, string join_feats, string output_feats, string search_radius)
//https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic10957.html
var progDlg = new ProgressDialog("Running spatial join", "Cancel", 100, true);
progDlg.Show();
var progsrc=new CancelableProgressorSource(progDlg);
System.Windows.MessageBox.Show("Progress bar show");
var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
var parameters = await QueuedTask.Run(() =>
var join_operation = "JOIN_ONE_TO_ONE";
var match_option = "INTERSECT";
var field_map = "";
return Geoprocessing.MakeValueArray(target_feats, join_feats, output_feats, join_operation,
"KEEP_COMMON", field_map, match_option, search_radius);
GPExecuteToolFlags flags = GPExecuteToolFlags.AddOutputsToMap | GPExecuteToolFlags.GPThread;
var toolResult = await Geoprocessing.ExecuteToolAsync("SpatialJoin_analysis", parameters, environments, null, null, flags);
// dialog hides itself once the execution is complete
progDlg.Hide();
System.Windows.MessageBox.Show("Progress bar hide");
if (toolResult.IsFailed == true)
Geoprocessing.ShowMessageBox(toolResult.Messages, "GP Messages", toolResult.IsFailed ?
GPMessageBoxStyle.Error : GPMessageBoxStyle.Default);
return !(toolResult.IsFailed);
Wolf
by Esri Regular Contributor
I fixed your snippet above.   I guess the main issue was that the  CancelableProgressor parameter for ExecuteToolAsync is missing.
    protected override async void OnClick()
      var done = await ProcessSpatialJoin(@"Crimes", @"Portland Precincts", @"C:\Data\Interacting with Maps\Interacting with Maps.gdb\Crimes_SpatialJoin", "50 Yards");
      MessageBox.Show($@"Process done: {done}");
      var progDlg = new ProgressDialog("Running spatial join", "Cancel");
      progDlg.Show();
      //System.Windows.MessageBox.Show("Progress bar show");
        var field_map = "";
      GPExecuteToolFlags flags = GPExecuteToolFlags.AddOutputsToMap | GPExecuteToolFlags.GPThread | GPExecuteToolFlags.AddToHistory;
      var toolResult = await Geoprocessing.ExecuteToolAsync("SpatialJoin_analysis", parameters, environments, progsrc.CancellationTokenSource.Token, null, flags);
      //// dialog hides itself once the execution is complete
      //progDlg.Hide();
      //System.Windows.MessageBox.Show("Progress bar hide");
I tried with release 3.0 as well and it worked with 3.0 too:
GKmieliauskas
If you are running add-ins from Visual studio it will not show progress dialog ( no matter Debug or Release mode) . Try to run it directly from ArcGISPro.exe executable.
HelenZhou
The ArcGIS Pro is not launched from Visual Studio. Thanks
GKmieliauskas
1. Try to delete line:
2. Try to change geoprocessing  flag by removing GPExecuteToolFlags.GPThread.
3. If your geoprocessing fails (invalid parameters and etc.) when you will not see progress dialog too
HelenZhou
@GKmieliauskas , Thanks. The tool is working. I just need to add a progress bar for the long geoprocessing time.
I have tried to remove the code specified in item 1 and 2. Progress bar still doesn't display.
GKmieliauskas
Look at the @Wolf sample in ArcGIS Pro SDK thread
It uses CancelableProgressorSource as parameter for geoprocessing call
HelenZhou
Thanks again @GKmieliauskas. I have checked @Wolf sample. But, According to this ESRI documentation https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic9384.html There is no parameter of CancelableProgressor in the parameter list for Geoprocessing.ExecuteToolAsync
HelenZhou
Thanks for the link. I understand they are two methods with different parameters. My code still does not show progress bar after matching with the example. On the other hand, during running the geoprocess tool, the ArcGIS Pro is frozen until the tool is finished.
Wolf
This code worked for me:
      try
        var progDlg = new ProgressDialog("Running Geoprocessing Tool", "Cancel");
        // prepare input parameter values to CopyFeatures tool
        string input_data = @"C:\Data\Admin\AdminSample.gdb\TestArea";
        string out_workspace = ArcGIS.Desktop.Core.Project.Current.DefaultGeodatabasePath;
        string out_data = System.IO.Path.Combine(out_workspace, "TestArea2");
        // make a value array of strings to be passed to ExecuteToolAsync
        var parameters = Geoprocessing.MakeValueArray(input_data, out_data);
        // execute the tool
        await Geoprocessing.ExecuteToolAsync("management.CopyFeatures", parameters,
            null, new CancelableProgressorSource(progDlg).Progressor, GPExecuteToolFlags.Default);
        progDlg.Hide();
      catch (Exception ex)
        MessageBox.Show (ex.ToString ());
the difference is that i set the 'delayedShow' parameter for the ProgressDialog constructor to false (not specifying that parameter causes it to be set to false), and i removed the progDlg.Show() line.
