Set DisplayField property for StandaloneTable
1350
11-08-2018 07:24 AM
BradJones3
I have a button that loads some standalone tables that are in a 1:M relationship classes with other layers.  I
want to set the DisplayField property of the related tables to the date field so my users can see the date attributes in the popups.
 How do I go about this?  I'm at a loss on where to go from here.
public void SetDisplayField(string tableName, string fieldName)
    var mapView = MapView.Active.Map;
    QueuedTask.Run(() =>
        IReadOnlyList<StandaloneTable> tables = mapView.FindStandaloneTables(tableName);
        foreach (var table in tables)
            var cimTableDefinition = table.GetDefinition() as CIMStandaloneTable;
            var displayField = cimTableDefinition.DisplayField;
BradJones3
This what I used in the end.
    public void SetDisplayField(StandaloneTable saTable, string tableName, string fieldName)
                //Gets a list of the standalone tables in map with the name specified in the method arguments.
                    //Gets the list of fields from the stand alone table.
                    var descriptions = table.GetFieldDescriptions();
                    foreach (var desc in descriptions)
                        if (desc.Name == fieldName) // If field name equals "COMPDTTM"
                            //Creates variable that's equal to "COMPDTTM"
                            string displayName = desc.Name;
                            // Get's the CIM definition from the StandaloneTable
                            // Set DisplayField property of the cimTableDefinition equall to displayName("COMPDTTM")
                            cimTableDefinition.DisplayField = displayName;
                            // USe the SetDefinition method to apply the modified table definition (cimTableDefninition)
                            saTable.SetDefinition(cimTableDefinition);
                            // Use to check the result when debugin in break point.
                            var result = table.GetDefinition().DisplayField;
BradJones3
