Selection.Combine() throwing error in 3.3 but worked in 3.1
1142
11-22-2024 07:42 AM
dd_dev
I have a block of code that creates a single selection object from the selections of each layer of a Group Layer. This worked fine in Pro 3.1 but now in the process of updating to 3.3 and it is failing with "ArcGIS.Core.ObjectDisconnectedException: 'This object has been previously disposed and cannot be manipulated.'" despite all objects having _disposed as false.
The original layer is a nested group layer, groups within groups. It fails when there are selections in both of the nested groups being combined.
private Selection GetSelectionFromGroupLayer(Layer inputLayer)
    Selection featureSelection = null;
    var groupLayer = (GroupLayer)inputLayer;
    IList<Layer> groupLayers = groupLayer.GetLayersAsFlattenedList().ToList();
    for (int i = 0; i < groupLayers.Count; i++)
        var layer = groupLayers[i];
        if (layer is FeatureLayer)
            var featureLayer = (FeatureLayer)layer;
            if (featureLayer.SelectionCount != 0)
                if (featureSelection == null)
                    featureSelection = featureLayer.GetSelection();
                else
                    Selection selection = featureLayer.GetSelection();
                    //fails here
                    featureSelection = featureSelection.Combine(selection, SetOperation.Intersection);
            featureLayer = null;
        layer = null;
    return featureSelection;
 Any suggestions?
UmaHarano
Hi @dd_dev
I tried your code with a collection of nested feature layers from a file gdb and I did not see the crash. My map group layers look like this screenshot below. Can you please give me a information on your layers?
dd_dev
All of the sublayers have the same data source, an Oracle Enterprise Geodatabase, just different definition queries. If all selected features are from the same sublayer, it's fine. Once there are features selected from multiple sublayers the error is thrown.
UmaHarano
Hi @dd_dev
Would it be possible to reach out to Esri support for this one? I am not able to repro this.
Thanks!
Uma
