SchemaBuilder Error
2328
07-05-2023 03:59 PM
tzz_12
Hi Everyone,
I am trying to use a feature layer description to create an identical new feature class with different fields. I know there are several ways to do this. I tried doing it on DLL. The feature class and fields I want is created correctly, but when I import it into the map, the feature layer does not show, because the shape area, length and polygon fields were not transferred to the new feature class. How can I fix this?
 QueuedTask.Run(() =>
                var LayerDef = Layer.GetFeatureClass().GetDefinition();
                using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(gdb))))
                    // Creating the attribute fields
                    FieldDescription objectIDFieldDescription = FieldDescription.CreateObjectIDField();
                    FieldDescription field1 = new FieldDescription("field1", FieldType.Double);
                    FieldDescription field2 = new FieldDescription("field2", FieldType.Double);
                    List<FieldDescription> fieldDescriptions = new List<FieldDescription>()
                    {objectIDFieldDescription, field1, field2
                    ShapeDescription shapeDescription = new ShapeDescription(IntersectSort.GetFeatureClass().GetDefinition());
                    FeatureClassDescription LayerDescription = new FeatureClassDescription("Layer_Name", fieldDescriptions, shapeDescription);
                    SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
                    schemaBuilder.Create(LayerDescription);
                    bool success = schemaBuilder.Build();
Wolf
by Esri Regular Contributor
i haven't tried this but i think these lines have an issue:
ShapeDescription shapeDescription = new ShapeDescription(IntersectSort.GetFeatureClass().GetDefinition());FeatureClassDescription LayerDescription = new FeatureClassDescription("Layer_Name", fieldDescriptions, shapeDescription);
maybe try this instead:
FeatureClassDefinition originalFeatureClassDefinition = IntersectSort.GetFeatureClass().GetDefinition();
FeatureClassDescription originalFeatureClassDescription = new FeatureClassDescription(originalFeatureClassDefinition);
FeatureClassDescription LayerDescription = new FeatureClassDescription("Layer_Name", fieldDescriptions, originalFeatureClassDescription.ShapeDescription);
tzz_12
Thanks Wolf for your help. I tried your method, and it has the same result. For some reason, the feature layer is not showing on the map.
Wolf
It is working for me.  The following snippet will create a new FeatureClass class "NewLayer" from an existing "TestPolygons" feature layer using the same shape definition but with two new fields.  Then it adds the new FeatureClass to the map as "New: NewLayer" and finally copies all existing features from "TestPolygons" to "New: NewLayer".
protected override async void OnClick()
      var originalLayerName = "TestPolygons";
      var newLayerName = "NewLayer";
      var originalLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(fl => fl.Name.Contains(originalLayerName)).FirstOrDefault();
      var isOk = await QueuedTask.Run<bool>(() =>
        var LayerDef = originalLayer.GetFeatureClass().GetDefinition();
        using Geodatabase geodatabase = new(new FileGeodatabaseConnectionPath(new Uri(Project.Current.DefaultGeodatabasePath)));
        FieldDescription field1 = new("field1", FieldType.Double);
        FieldDescription field2 = new("field2", FieldType.Double);
        List<FieldDescription> fieldDescriptions = new()
        FeatureClassDefinition originalFeatureClassDefinition = originalLayer.GetFeatureClass().GetDefinition();
        FeatureClassDescription originalFeatureClassDescription = new(originalFeatureClassDefinition);
        FeatureClassDescription LayerDescription = new(newLayerName, fieldDescriptions, originalFeatureClassDescription.ShapeDescription);
        SchemaBuilder schemaBuilder = new(geodatabase);
        return success;
      if (!isOk)
        MessageBox.Show($@"Failed to create {newLayerName}");
        return;
      // add the new FeatureClass to the map
      var newLyr = await QueuedTask.Run(() =>
        var newFc = geodatabase.OpenDataset<FeatureClass>(newLayerName);
        return LayerFactory.Instance.CreateLayer<FeatureLayer>(new FeatureLayerCreationParams(newFc) { Name = $@"New: {newLayerName}" }, MapView.Active.Map);
      // copy some data
        // create an edit operation
        EditOperation copyOperation = new EditOperation()
          Name = "Copy Data",
          ProgressMessage = "Working...",
          CancelMessage = "Operation canceled.",
          ErrorMessage = "Error copying polygons",
          SelectModifiedFeatures = false,
          SelectNewFeatures = false
        using var rowCursor = originalLayer.Search();
        while (rowCursor.MoveNext())
          using (var row = rowCursor.Current as Feature)
            var geom = row.GetShape().Clone();
            if (geom == null)
              continue;
            var newAttributes = new Dictionary<string, object>();
            newAttributes.Add("field1", 1.0);
            newAttributes.Add("field2", 2.0);
            copyOperation.Create(newLyr, geom, newAttributes);
        // execute the operation
        if (!copyOperation.Execute())
          MessageBox.Show($@"Copy operation failed {copyOperation.ErrorMessage}");
          return;
tzz_12
It works after some minor modification to the code, but when I kept the newAttributes in "copyOperation.Create(newLyr, geom, newAttributes)," it would show this error message, "Cannot convert from System.Collection.Generic.Dictionary<string,object> to System.Action<long>".  It works fine if I delete the newAttributes from the line tho. On a related note, how do I save the edits operations within the script to avoid doing it manually after the script runs? Thanks for your help Wolf!
Wolf
My sample code above is for release 3.0 and newer, if you are using ArcGIS Pro 2.x then the API is bit different.   Below is the snippet that works with 2.9, note the change in the copyOperation.Create line required by the 2.x API (the parameters are different):
        bool success = false;
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(Project.Current.DefaultGeodatabasePath))))
            ArcGIS.Core.Data.DDL.FieldDescription objectIDFieldDescription = ArcGIS.Core.Data.DDL.FieldDescription.CreateObjectIDField();
            ArcGIS.Core.Data.DDL.FieldDescription field1 = new ArcGIS.Core.Data.DDL.FieldDescription("field1", FieldType.Double);
            ArcGIS.Core.Data.DDL.FieldDescription field2 = new ArcGIS.Core.Data.DDL.FieldDescription("field2", FieldType.Double);
            List<ArcGIS.Core.Data.DDL.FieldDescription> fieldDescriptions = new List<ArcGIS.Core.Data.DDL.FieldDescription>()
                field1,
                field2
            FeatureClassDescription LayerDescription = new FeatureClassDescription(newLayerName, fieldDescriptions, originalFeatureClassDescription.ShapeDescription);
        return success;
    if (!isOk)
        return;
    // copy some data
            Name = "Copy Data",
        using (var rowCursor = originalLayer.Search())
                    if (geom == null)
                        continue;
                        { newLyr.GetFeatureClass().GetDefinition().GetShapeField(), geom },
                        { "field1", 1.0 },
                        { "field2", 2.0 }
                    copyOperation.Create(newLyr, newAttributes);
            return;
In order to save all edits you can use:
_ = Project.Current.SaveEditsAsync();
