Rotate point symbol based on a field
1911
02-06-2024 02:23 PM
AquanuityDevelopment
I just could not make this attribute driven symbology feature to work using ArcGIS Pro SDK.  The following is a snippet of my code:
var render = lyr.CreateRenderer(simpleRender) as CIMSimpleRenderer;
var cimExpressionInfoZ = new CIMExpressionInfo { ReturnType=ExpressionReturnType.Numeric, Expression = "$feature.Direction" };
var cimVisualVariableInfoZ = new CIMVisualVariableInfo { VisualVariableInfoType = VisualVariableInfoType.Expression, ValueExpressionInfo = cimExpressionInfoZ};
var listCIMVisualVariables = new List<CIMVisualVariable>
new CIMRotationVisualVariable {
VisualVariableInfoZ = cimVisualVariableInfoZ,
RotationTypeZ=SymbolRotationType.Arithmetic
render.VisualVariables = listCIMVisualVariables.ToArray();
lyr.SetRenderer(render);
I would like to rotate the symbol based on a field called "Direction" with angles range 0 - 360.  The symbols have been rotated but not according to the values in "Direction" fields.  Any help will be great appreciated.
GKmieliauskas
Try code below. It works for me.
        protected override async void OnClick()
            var featLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().First();
            await QueuedTask.Run(() =>
                var render = featLayer.GetRenderer() as CIMSimpleRenderer;
                var cimVisualVariableInfoXY = new CIMVisualVariableInfo
                    RandomMax = 360,
                    RandomMin = 0,
                    VisualVariableInfoType = VisualVariableInfoType.None
                    Title = "Custom",
                    ReturnType = ExpressionReturnType.Default,
                    RandomMax = 360,
                    RandomMin = 0,
                        VisualVariableInfoX = cimVisualVariableInfoXY,
                        VisualVariableInfoY = cimVisualVariableInfoXY,
                        RotationTypeZ=SymbolRotationType.Arithmetic,
                        NormalToSurface = false
                featLayer.SetRenderer(render);
GKmieliauskas
                    RandomMax = 360,
                    RandomMin = 0,
                    Title = "Custom",
                    RandomMax = 360,
                    RandomMin = 0,
@GKmieliauskas Thanks a lot.  It is working now!
CharlesMacleod
nice one!
