Query a raster for pixel value from ImageServer/AGOL
4822
8
04-28-2021 03:46 AM
Vidar
Hi
I have a raster published in AGOL and it’s URL is like this https://tiledimageservices1.arcgis.com/IB7Kf2F8K18M2LKr/arcgis/rest/services/fooRaster/ImageServer
I want to access the raster via the Pro SDK but NOT add it to the map, and the only example code I can find is below:
string dataSoureUrl = @”https://tiledimageservices1.arcgis.com/IB7Kf2F8K18M2LKr/arcgis/rest/services/fooRaster/ImageServer”;
ImageServiceLayer rasterLayer = null;
await QueuedTask.Run(() =>
       // Create a layer based on the url. In this case the layer we are creating is an image service layer.
       rasterLayer = (ImageServiceLayer)LayerFactory.Instance.CreateLayer(new Uri(dataSoureUrl), myMap);
The reason I don’t want to add it to the map – is because I am doing a “drill down” on about 10 rasters based on an x,y coordinate the user has selected on the map (with some background mapping of the world) – and extract the pixel value at that coordinate. It’s too much unnecessary overhead to load the rasters into Pro and do the analysis after the event.
Is there a way to query a pixel value in memory based on the an x,y location??
Tags (1)
GKmieliauskas
For creating layer in memory look here:
https://community.esri.com/t5/arcgis-pro-sdk-questions/making-a-group-layer-or-layer-in-memory/m-p/7...
To get pixel value from layer:
var raster = imageServiceLayer.GetRaster();
object pixelValue = raster.GetPixelValue(0, 150000, 150000);
Vidar
Thanks for your reply - I think the LayerParams only works with feature data, not rasters.  But the second part of your reply looks good.
GKmieliauskas
What about this workaround?
Create FeatureLayer and set to not display in Map.
//The catalog path of the feature layer to add to the map
var featureClassUriVisibility = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
//Define the Feature Layer's parameters.
var layerParamsVisibility = new FeatureLayerCreationParams(featureClassUriVisibility)
  //Set visibility
  IsVisible = false,
//Create the layer with the feature layer parameters and add it to the active map
var createdFC = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsVisibility, MapView.Active.Map);
Vidar
I think thats the same sort of solution in the link provided before - again, its dealing with FeatureLayers - but here we are dealing with rasters, specifically ImageServer. Also the example adds it to the map which I don't really want to do.
GKmieliauskas
HI,
I have checked right now. It works. Code below:
var imageServiceUriVisibility = new Uri(path);
var layerParamsVisibility = new LayerCreationParams(imageServiceUriVisibility)
//Set visibility
IsVisible = false,
// Creates a layer based on the url. In this case the layer we are creating is an image service layer.
imageServiceLayer = LayerFactory.Instance.CreateLayer<ImageServiceLayer>(layerParamsVisibility, MapView.Active.Map);
if (imageServiceLayer == null)
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Failed to create layer for url:" + path);
return null;
GKmieliauskas
It looks  like Pro only adds layer with unchecked visibility checkbox, I understand  that it does not show in TOC.
Sorry. 🙂
Vidar
It does work, I've tried it too - unfortunately it adds it to the map. Maybe I'll have to work with this until there is a better solution from ESRI.
Thanks for your help on this though.
Vidar
Is there anyone from ESRI who can give an official line on this - at the moment my add-in behaviour is horrible and clunky - I am having to add 10 rasters to my map before I can do my queries which is taking an inordinate amount of time and it looks clunky to the user. Plus I have to clean up and remove the layers after I have queried my rasters. It's just not an acceptable user experience.
