ProWindow wait cursor
1843
04-11-2018 12:43 PM
BrianBulla
Honored Contributor
I'm following the SDK community samples and opening up a Window (styled as a ProWindow) from the click event of a button.  The Window opens fine, and is in the esri style, but the cursor only displays on the form as a 'wait' cursor.  Does anyone know what might be happening?
My code is fairly simple.  To open the Window:
To style my Window:
<controls:ProWindow x:Class="AddressPointSelector_ArcPro.AddressWindow"
             xmlns:controls="clr-namespace:ArcGIS.Desktop.Framework.Controls;assembly=ArcGIS.Desktop.Framework"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:extensions="clr-namespace:ArcGIS.Desktop.Extensions;assembly=ArcGIS.Desktop.Extensions"
             mc:Ignorable="d"
             Title="Address Tool"
             d:DesignHeight="300" d:DesignWidth="300">
        <controls:ProWindow.Resources>
            <ResourceDictionary>
                <ResourceDictionary.MergedDictionaries>
                    <extensions:DesignOnlyResourceDictionary Source="pack://application:,,,/ArcGIS.Desktop.Framework;component\Themes\Default.xaml"/>
                </ResourceDictionary.MergedDictionaries>
            </ResourceDictionary>
        </controls:ProWindow.Resources>
        <Grid>
        </Grid>
</controls:ProWindow>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Thanks!
Tags (1)
UmaHarano
Hi Brian
I tried this in a simple add-in. I am not seeing the wait cursor.
BrianBulla
Honored Contributor
Hi Uma,
Thanks for checking into that.  Seems to be that my addrWindow.Show() being within the QueuedTask.Run is what is causing the problem.  I have changed it, so now it is like this:
async protected override void OnClick()
            await QueuedTask.Run(() =>
                //some logic here
            AddressWindow addrWindow = new AddressWindow();
            addrWindow.Show();
Thanks!
CharlesMacleod
Brian, generally speaking, the only UI you should use in conjunction with a QueuedTask is a progressor. Messageboxes, windows ("Dialogs'), etc should be invoked on the UI thread.
