ProgressDialog not showing even without debugging mode .net sdk
3301
01-14-2023 09:03 PM
JohnP18
I have created a ProgressDialog but not able to see even without debugging mode on button click event.
protected override async void OnClick()
using (var progress = new ProgressDialog("Showing Progress", "Canceled", 100, false))
var status = new CancelableProgressorSource(progress);
status.Max = 100;
progress.Show();
await QueuedTask.Run(async () =>
uint step = 0;
for (var idx = 0; idx < 10; idx++)
await Task.Delay(1000);
status.Progressor.Value += 10;
status.Progressor.Status = (status.Progressor.Value * 100 / status.Progressor.Max) + @" % Completed";
status.Progressor.Message = "Message " + status.Progressor.Value;
}, status.Progressor);
progress.Hide();
Any ideas here??
GKmieliauskas
If you are running add-ins from Visual studio it will not show progress dialog ( no matter Debug or Release mode) . Try to run it directly from ArcGISPro.exe executable.
GKmieliauskas
I think that you update progress not from UI thread. This link could help you:
https://community.esri.com/t5/arcgis-pro-sdk-questions/best-way-to-show-progress/m-p/778671
JohnP18
@GKmieliauskas I don't have any separate Xaml to add the WPF Progress Bar. I just have a button in the tab. On that button click I am calling an api for which I have to use the progress till the time we will get the response. The example shows the Wpf progress bar not the pro one.
GKmieliauskas
Wolf
by Esri Regular Contributor
There are some examples that show WPF progressors on Dockpanes in the 2022 Palm Springs tech session (https://esri.github.io/arcgis-pro-sdk/techsessions/2022/PalmSprings/ImprovingYourDockpaneandProWindo...) , all 2022 tech sessions are here, the one you want to look at is called ' Improving Your Dockpane and ProWindow':
Tech Sessions · Esri/arcgis-pro-sdk Wiki (github.com)
CharlesMacleod
This looks suspect to me - the await on the Task.Delay.
I think if u change your code to:
await QueuedTask.Run(() =>
   Task.Delay(1000).Wait();//block
You will get the effect u are after. Also, 1000 might be a little bit too quick. 2000+ may be better. Scratch that - u r in a loop, 1000 is fine.  From memory I think there is an option on the ProgressDialog ctor - delayedShow. Default is true so u can set that to false to have the dialog immediately show. Last, I dont think the progress.Hide() is necessary.
