Passing parameters to Icommand
3165
6
03-16-2023 10:55 AM
Cheetah24
Hi
How can I pass a parameter using the following code where commandId is a custom class that extends MapTool. Is CanExecute implemented to accept parameters? I always get false when I specify an object.
IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper(commandId);
var command = wrapper as ICommand;
if ((command != null) && command.CanExecute(null))
  command.Execute(null);
GKmieliauskas
You can use your module for parameter exchanging. Make property in module with public get and set methods. Before Execute call set parameter, and on tool activating read it.
GKmieliauskas
Cheetah24
Thanks for the response, this example uses binding and don't think it's translates to what I'm trying to do with Maptool.
GKmieliauskas
RichardDaniels
MVP Regular Contributor
if your always getting null, you should check that you have Activated the tab your button is on.
FrameworkApplication.ActivateTab('esri_mapping_homeTab');
One activated you execute the button with command..Execute() as you show.
Cheetah24
Hi. I only get false if i attempt to pass a parameter to canexecute()
Wolf
by Esri Regular Contributor
Neither classes derived from Button (processing your OnClick) nor classes derived from MapTool (processing your Tool) are accepting parameters.  If you need to configure any of these button or tool classes, i recommend using properties in your Module derived class (or settings if that's appropriate).  Your module derived class is a singleton and easily accessible from any of your code.
internal class Module1 : Module
    private static Module1 _this = null;
    internal static string MyToolSetting
      get; set;
To access this from your tool (within the same project):
internal class MapTool1 : MapTool
  private string myParameter;
  public MapTool1()
    IsSketchTool = true;
    SketchType = SketchGeometryType.Rectangle;
    SketchOutputMode = SketchOutputMode.Map;
  protected override Task OnToolActivateAsync(bool active)
    myParameter = Module1.MyToolSetting;
    return base.OnToolActivateAsync(active);
