Open standalone table from map service
4507
10
06-05-2018 08:08 AM
by Anonymous User
Not applicable
To access a map service table as a standalone table it seems I have to specify a table container (map) in order to create an instance of the table e.g. StandaloneTableFactory.Instance.CreateStandaloneTable(url, map)
Is there a way I can get an instance of the map service table to query it without adding it to a map? This table is hosted in an ArcGIS Server Map Service.  I want to avoid using the ArcGIS Rest Query endpoint directly.
For example in the Pro SDK I can open a geodatabase table using  gdb.OpenDatase<Table>(name)
Basically I want to query some tables using .Search() which works fine, but I don't want them in the map.
Cheers
EdwardBlair
This is very helpful, Rich.   Thanks!
